React2Shell Exploited / Abused on DeltaChat [Invalid URL at renderElement]
I’m done with any project using electron,react,next and similar node based projects with dependencies hells. The fact you guys are advertising as “audited” will also blindly lead people in bad situations. You should have a security.txt or at least be transparent with the user. React2Shell Deep Dive: CVE-2025-55182 Exploit Mechanics | Wiz Blog
I Like the project, protocol but the chain of supply is a major problem, chromium binary as well.
I honestly done with any applications like I just stated
This CVE is in CISA’s Known Exploited Vulnerabilities Catalog
Reference CISA’s BOD 22-01 and Known Exploited Vulnerabilities Catalog for further guidance and requirements.
Vulnerability Name Date Added Due Date Required Action
Meta React Server Components Remote Code Execution Vulnerability 12/05/2025 12/12/2025 Apply mitigations per vendor instructions, follow applicable BOD 22-01 guidance for cloud services, or discontinue use of the product if mitigations are unavailable.
Weakness Enumeration
CWE-ID CWE Name Source
CWE-502 Deserialization of Untrusted Data cwe source acceptance level NIST
Known Affected Software Configurations Switch to CPE 2.2
Configuration 1 (hide)
cpe:2.3:a:facebook:react:19.0.0:*:*:*:*:*:*:*
Show Matching CPE(s)
cpe:2.3:a:facebook:react:19.1.0:*:*:*:*:*:*:*
Show Matching CPE(s )
cpe:2.3:a:facebook:react:19.1.1:*:*:*:*:*:*:*
Show Matching CPE( s)
cpe:2.3:a:facebook:react:19.2.0:*:*:*:*:*:*:*
In the famous fairy tale “The Emperor’s New Clothes,” the Emperor is tricked into believing he is wearing a magnificent robe when naked. This story is a metaphor for the dangers of blindly trusting open-source software without carefully evaluating its security risks. Just as the Emperor’s courtiers were afraid to speak up for fear of being ridiculed, many organizations are hesitant to criticize open-source software for fear of being seen as behind the times or ungrateful.
The very openness that fuels open-source software popularity creates a double-edged sword. While readily available source code fosters collaboration and rapid innovation, it also grants adversaries a detailed map of potential vulnerabilities. Imagine a castle with its blueprints plastered on the gatehouse walls; any cunning foe could exploit hidden passages or weaknesses in the defenses. This transparency makes open-source software a lucrative target for malicious actors, particularly nation-state actors and sponsored advanced persistent threats (APTs) with sophisticated attack capabilities.<
The Emperor’s delusion is often apparent in the open-source software community. FOMO, hype, and bandwagon effects can propel certain projects to stardom without thorough security scrutiny. Organizations eager to embrace the latest shiny tool may overlook critical vulnerabilities, exposing themselves to potential breaches with catastrophic consequences. Just because everyone admires the “beautiful” Emperor’s non-existent attire does not make it real. [1]
Post your group on the social media, wait 1-2 days or grab of many react2shell PoC and adapt it for delta chat.
Debug logs https://paste.sh/978f576b-5ef5-4347-83f4-66804158a677
https://paste.sh/978f576b-5ef5-4347-83f4-66804158a677 Logs
ansport 6: IDLE entering wait-on-remote state in folder \"INBOX\"."
2026-08-04T21:05:29.006Z	core/event            	INFO	""	9	"src/imap/select_folder.rs:41: Expunge messages in \"INBOX\"."
2026-08-04T21:05:29.122Z	core/event            	INFO	""	9	"src/imap/select_folder.rs:44: Close/expunge succeeded."
2026-08-04T21:05:29.237Z	core/event            	INFO	""	9	"src/imap/select_folder.rs:78: Transport 1: Selected folder \"INBOX\"."
2026-08-04T21:05:29.349Z	core/event            	INFO	""	9	"src/imap/idle.rs:67: Transport 1: IDLE entering wait-on-remote state in folder \"INBOX\"."
2026-08-04T21:06:00.475Z	core/event            	INFO	""	1	"src/ephemeral.rs:614: Ephemeral loop waiting for deletion in 156h 40m 13s or interrupt"
2026-08-04T21:06:00.489Z	core/event            	INFO	""	1	"src/mimefactory.rs:479: Scale up origin of Chat#12 recipients to IncomingTo."
2026-08-04T21:06:00.493Z	core/event            	INFO	""	1	"src/chat.rs:2884: Message Msg#3077 will be sent in one shot (no pre- and post-message). Size: 6.28 KiB."
2026-08-04T21:06:00.494Z	core/event            	INFO	""	1	"src/scheduler.rs:613: SMTP fake idle interrupted."
2026-08-04T21:06:00.499Z	core/event            	INFO	""	1	"src/smtp.rs:538: Selected rows from SMTP queue: [1030]."
2026-08-04T21:06:00.499Z	core/event            	INFO	""	1	"src/smtp.rs:386: Try number 1 to send message Msg#3077 (entry 1030) over SMTP."
2026-08-04T21:06:00.530Z	renderer/message-parser	ERROR	"\nparseAndRenderMessage (file:///app/delta/resources/app/src/components/message/MessageParser.tsx:152:9),\nComponent (file:///app/delta/resources/app/src/components/message/MessageBody.tsx:99:10),\nrenderWithHooks (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:4351:21),\nupdateFunctionComponent (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:6497:15),\nupdateSimpleMemoComponent (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:6237:10),\nupdateMemoComponent (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:6178:9),\nbeginWork (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:7784:14),\npM (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:11305:14)"	"parseAndRenderMessage failed:"	{"input":"Warez (scene) Related\n\nWhat is Warez/The Scene?\nwikipedia.org/wiki/Warez 9/5/13\nwikipedia.org/wiki/Warez_scene 9/5/13\nwikipedia.org/wiki/Warez_group 9/5/13\nwikipedia.org/wiki/List_of_warez_groups 9/5/13\nwikipedia.org/wiki/Topsite_(warez) 10/3/13\nwikipedia.org/wiki/Nuke_(warez) 4/22/15\nwikipedia.org/wiki/Standard_(warez) 9/5/13\nwikipedia.org/wiki/.nfo 4/22/15\nwikipedia.org/wiki/Pirated_movie_release_types 9/5/13\nwikipedia.org/wiki/Copyright_infringement_of_software 9/5/13\nwikipedia.org/wiki/Copyright_infringement_of_audio-visual_works 9/5/13\nwikipedia.org/wiki/Operation_Buccaneer 10/3/13\nwikipedia.org/wiki/Operation_Fastlink 10/3/13\nwikipedia.org/wiki/Operation_Safehaven 4/22/15\nwikipedia.org/wiki/Operation_Site_Down 4/22/15\nwikipedia.org/wiki/Bulletin_board_system 10/3/13\n\nNo Copy (2008) (a brief history of piracy/filesharing) 10/3/13\n\nwired.com/2005/01/topsite/ 9/5/13\namazon.com/How-Music-Got-Free-Industry/dp/0525426612 | new yorker | vice 10/14/15\namazon.com/Software-Piracy-Exposed-Paul-Craig/dp/1932266984 (mediafire) 11/5/16\nfirstmonday.org/ojs/index.php/fm/article/view/5546/4125 10/15/14\ndl.acm.org/citation.cfm?id=2858036.2858341 (sci-hub link) 6/3/16\nonlinelibrary.wiley.com/doi/10.1002/1944-2866.POI369/abstract (sci-hub link) 7/9/16\n2600_Guide_to_Internet_Piracy-TYDJ.txt (from archive.org) 9/5/13\n\nreddit.com/r/IAmA/iama_ex_warez_scene_member_ama/ 4/15/14\nreddit.com/r/IAmA/i_run_a_topsite_ftp_server_and_im_in_the_piracy/ 5/13/14\nreddit.com/r/IAmA/i_cracked_software_for_the_warez_appsgames_scene/ 5/13/14\nreddit.com/r/IAmA/iama_for_9_years_i_was_a_member_in_some_of_the/ 5/13/14\nreddit.com/r/IAmA/i_was_in_a_major_mp3_releasing_group_in_the/ 5/13/14\nreddit.com/r/IAmA/hi_reddit_iama_now_retired_scener_who_was_a/ 5/13/14\nreddit.com/r/trackers/iama_retired_member_of_the_piracy_scene_amaa/ 5/13/14\n[...]","error":{"stack":"TypeError: Failed to construct 'URL': Invalid URL\n    at renderElement (file:///app/delta/resources/app/src/components/message/MessageParser.tsx:50:19)\n    at file:///app/delta/resources/app/src/components/message/MessageParser.tsx:147:11\n    at Array.map (<anonymous>)\n    at parseAndRenderMessage (file:///app/delta/resources/app/src/components/message/MessageParser.tsx:146:19)\n    at Component (file:///app/delta/resources/app/src/components/message/MessageBody.tsx:99:10)\n    at renderWithHooks (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:4351:21)\n    at updateFunctionComponent (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:6497:15)\n    at updateSimpleMemoComponent (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:6237:10)\n    at updateMemoComponent (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:6178:9)\n    at Rx (file:///app/delta/node_modules/.pnpm/react-dom@19.2.0_react@19.2.0/node_modules/react-dom/cjs/react-dom-client.production.js:7784:14)","message":"Failed to construct 'URL': Invalid URL"}}
2026-08-04T21:06:00.604Z	core/event            	INFO	""	1	"src/smtp/send.rs:62: Message len=6427 was SMTP-sent to 20 recipients.."
2026-08-04T21:06:00.604Z	core/event            	INFO	""	1	"src/smtp.rs:655: Sending MDNs."
2026-08-04T21:06:00.604Z	core/event            	INFO	""	1	"src/scheduler.rs:581: SMTP fake idle started."
2026-08-04T21:06:00.604Z	core/event            	INFO	""	1	"src/scheduler.rs:609: SMTP has no messages to retry, waiting for interrupt."
2026-08-04T21:06:00.634Z	core/event            	INFO	""	1	"src/imap/idle.rs:90: \"INBOX\": Idle has NewData ResponseData { raw: 4096, response: MailboxData(Exists(1707)) }"
2026-08-04T21:06:00.651Z	core/event            	INFO	""	1	"src/quota.rs:88: Transport 2: Updating quota."
2026-08-04T21:06:00.664Z	core/event            	INFO	""	1	"src/quota.rs:106: Transport 2: Updated quota."
Transparent about what?
We don’t use the code that is affected by the vulnerability you mentioned. See our lock file. It does not contain the mentioned libraries. We do not use React Server components.
Thanks for the report, we’ll take a look. Sorry about that. This is the place where the error occurs.
It has nothing to do with the vulnerability you mentioned. What happens is we parse the text of a message recognizing URLs to make them blue and clickable, but here the recognition is off, did not result in a valid URL.
Regarding the Threat Graph: not sure what to make of it, would appreciate if you could explain what it means (to you at least), preferably over the proper security vulnerability reporting channel (as long as there is something to say, apart from the scary-looking red color).
So far I see nothing of substance, but I appreciate the concern.
I did not find it , i got exploited by it. I never intended to “report” something that is public, have advisory, fixes released and I already have to deal with my own issues because of it. I am simply trying to raise awareness in hope that people with less “experiences” with computers do not fall victim to such. The application never segfault’d, if i was not “paranoid” and didn’t start looking at logs and had Thor, velociraptor running it would have probably went under my radar since i did not anticipate it and I my threat model was far from adequate for such. I’m simply getting tired of electron/nodes based app which caused a lot’s of my security issues in past years .
I’m still investigating stuff he uploaded, sent as payload reversing most of stuff it altered. GitHub - freeqaz/react2shell: An analysis of CVE-2025-55182 and CVE-2025-66478 -- the vulnerabilities behind React2Shell. Tools, technical information, etc · GitHub sadly it exist because of how React Server Components deserialize If the attacker crafts a payload with an Action ID that points to their module#constructor reference, React resolves it like a normal action and executes it. That “action” is actually their malicious function. CVE-2025-55182-research/test-chunked-bypass.cjs at main · ejpir/CVE-2025-55182-research · GitHub https://cloud.google.com/blog/topics/threat-intelligence/threat-actors-exploit-react2shell-cve-2025-55182
And how do you know that?
The bundle.js file you uploaded exactly matches what I get when building locally. What is your point? That it’s the attacker’s payload?
Given that the file is only supposed to be executed in the browser process, how exactly would it do all the crazy stuff that is listed, i.e. create files, change registry, etc?
And where did you get the react-dom-client.production.js file? I’m pretty sure we’re not bundling it.
