Ask and answer questions about Delta Chat, finding solutions together.
This category is for Delta Chat end user, exchanging experiences and discussing problems while using Delta Chat clients, their favourite messenger app.
Please be as precise and detailed as possible. It will increase your chances, that someone else understands your problem. Only if people know what you expect, and what you did to find the problem, they can help you.
If someone solved your problem, award them! Mark their topic as solved. This encourages people to help each other, and helps others to find the solution if they encounter the same problem.
Questions about Bots, Chatmail, Mini Apps, etc. should go to their corresponding categories.
