Allow to set sending default transport different from default receiving transport
Be able to select a default receiving transport, different from the default sending transport.
This could allow to have a classic mail as receiver (larger storage, no messages deleted after 20 or 30 days), and a chatmail as sender (no rate or recipients sending limitations, lower latency).
Also, the pressure on chatmail operators is reduced because they could set up shorter message retention periods.
I noticed that when you send a message through a chatmail relay, it is also sent to your classic account transport, which also preserves your own messages to be synchronized beyond the chatmail deletion span.
Default sending and receiving transports are the same.
You can already “hide” the relay (called “transport” internally), so you then have it, but it is not advertised and your contacts don’t send the messages back to it.
The problem here is that in the UI, unhiding the relay (internally set_transport_unpublished(..., false) and selecting it as the sending relay is the same action. So as soon as you select the relay for sending, it becomes published/unhidden.
What we can do without changing the UI much, is to allow long-press (looking at Delta Chat for Android UI now) on the currently selected sending relay, then in addition to “Edit relay” allow the “Hide Relay” option in the place where “Remove Relay” is normally shown. So you will end up with a sending but hidden relay by doing this.
There is a corner case of this making it possible to hide all your relays, but this is not different from using an old version of Delta Chat, when you advertise no relays in the key, the From address is used, so it will not break even if not handled explicitly.
I imagined an extra bullet column for send relay, but your solution is far cleaner. No visible change in the UI for the general user.
It would be awesome to have that possibility. And far easier to convince people to switch their daily driver messenger :slight_smile:
But wait, for this usecase, what is the problem with just using both the classic email and chatmail as a receiver and using chatmail for sending? You send from chatmail so you don’t have ratelimit, you receive on classic email as well as chatmail so you get all messages even after 20 days.
Chatmail currently may run over quota in such usecase if you receive a lot of messages within 20 days, this will not be a problem after feat: automatic oldest-first message removal from mailboxes to always stay under max_mailbox_size by hpk42 · Pull Request #929 · chatmail/relay · GitHub and may also be not a problem for your usage as already.
Maybe I did not understand correctly how multi transport works.
If I set a chatmail as default relay and a contact sends me a message, is that message also sent to the classic mail transport?
If that’s the case, then you are right, my use case is already covered.
A second device which was offline for more than 20 days will fetch the message from the classic mail transport (not set as default).
Is this correct?
So an ideal setup would be a couple of chatmail transports (one of them as default) and a classic account to assure less frequently used devices don’t miss messages.
If both you and your contact is using the latest version of DC, the message is sent to both of your transports, to the chatmail relay and to the classic mail server. Then you download the message from one of them, and on the other notice that it is the same message and skip it.
Yes, if you then wait 20 days, the message will only remain on the classic mail server. When your second device comes online, it will download the message from there.
You can do it by setting up a profile with a classic email server, then add chatmail relays. Or if you already have a profile, you can add classic email using dclogin URL generator app. Just make sure you are not reusing the same mailbox for different profiles, create a new one for each.
Amazing!
I’ve already used the dclogin xdc app, and have separated the previously mixed accounts and moved to exclusive classic mails for each DC profile.
This thread should be rebranded as help instead of feature proposal - don’t know how to do that.
Thanks! - DC is the best!
