Are backups encrypted?
Are backups exported by the iOS app encrypted? Should I be extra careful while handling them?
Hello :wave:,
they are not yet encrypted. The backups are TAR archives containing a SQLite database and the account’s media. This also applies to the backups of DC desktop.
In the meantime, maybe the UI should warn the user to be extra-careful with those backups?
there is an option in the Android client to encrypt the database, currently the blobs are saved outside the SQLite database so it is is not that strong protection, also I think the client doesn’t give control over the password to decrypt the database, so my guess is that backup is saved with unencrypted database or including the database password, otherwise I think other clients wouldn’t be able to import the backup
I don’t remember well, but IIRC the app already give warnings about not storing backups for too long and that it is dangerous, at least on Android
Is the key also included?
yes, everything is in the backup.
But this is only when you do an explicit, manual, tar file backup export, right? It’s not something iOS does in the background on its own and uploads to its creepy services?
yes, backups are only created upon explicit user action and only locally
