Call and video calls
How do I use Delta Chat to make calls and video calls?
You can send invitation links to rooms, for example by setting webrtc URL in the settings to https://meet.jit.si/.
As for more integrated calls, see discussion at
Also see here:
May I ask why https://meet.jit.si/$ROOM is not set as default with a fresh installation (of the Android app)?
Because it’s the obvious choice (if not having an alternative), but as I have just seen, on v1.14.5 the option Video chat instance is not configured by default.
Delta Chat does not to rely on any servers out of the box. The only exception is the Thunderbird autoconfig database which is only used during autoconfiguration as a fallback if provider is not found in the built-in database and does not provide its own autoconfig XML. It should be imported into built-in provider database at some point too.
Another exception is Mapbox tile servers, but this feature is still considered experimental and disabled by default. Delta Chat also opts out of data collection by Mapbox, but technically Mapbox may still obtain some data, so switching to offline OpenStreetMap maps using some OSM library or Peermaps renderer is likely needed before it can enabled by default.
Official Jitsi Meet instance has its own terms and conditions, privacy policy, and runs behind Cloudflare, which may be not what users want.
I understand, but it would have been nice if https://meet.jit.si/$ROOM were set by default nonetheless, so that there is something present to start with, because with the present state one has no other choice than to explain to the other party what to configure to make it work. So it’s actually no out-of-the-box experience right now.
BTW Is there a reason for the Video chat instance example showing https://meet.jit.si/$ROOM when just https://meet.jit.si also works?
First I though the $ROOM addition is necessary for getting a random room name assigned each time a Video chat is initated, but it does the same with https://meet.jit.si as well.
For getting a random room name assigned each time a Video chat is initated you need to add $NOROOM
Actually I have first tried https://meet.jit.si/$ROOM and then just https://meet.jit.si and both result in getting a random room name assigned each time a Video chat is initiated.
As said, the text above the entry field for the URL shows https://meet.jit.si/$ROOM as example, and I wondering what possible ways there are to add a Jitsi Meet URL.
Are possible Jitsi Meet URL parameters documented somewhere?
https://meet.jit.si is the same as https://meet.jit.si/$ROOM.
$NOROOM was added in this thread to support Webex:
Ahem, why would anyone want to use Cisco Webex? :thinking:
I guess there is no such easy way to just use a self-hosted Nextcloud instance with the Nextcloud Talk app for that?
Because there are so many instances to choose from here.
This is a list of some instances:
Your answer relates to “many instances” of Jitsi servers, but that wasn’t the question.
Of course there are a lot of option when going for Jitsi, and you can choose whichever server you want, but it would have been nice if one (or with a drop-down list + optional entry field) would have been set as the default for a new app installation simply because right now that option is not configured at all, which means Video calls are not working out-of-the-box and I first have to explain to the other party (who may not be that technically gifted) what to do in the advanced options to make it work. That’s just not a good 1st user experience.
Even better, why not use something like jitsi.random-redirect.de which redirects to a random server as the default setting?
Using a random instance is usually a bad idea when some of the instances are less reliable than others. It is better to stick to one instance that works for you and switch when it fails.
There are some experiments to add call UI at calls by r10s · Pull Request #2638 · deltachat/deltachat-ios · GitHub
No real calls yet, still using Jitsi.
iroh is experimenting with calls at GitHub - n0-computer/callme
