Chatmail - Quota limit
So I have my own chatmail server, in which file(s) do you edit to increase the mailbox quota limit ?
your chatmail.ini file, look there for max_mailbox_size
then you just re-run the deployment command and it will update the config in dovecot
Okay, the one in dovecot.conf needs to be changed too right ?
then you just re-run the deployment command and it will update the config in dovecot, you could do it manually if you know what you are doing ofc
See also Create a normal email with chatmail (I'm an admin).
I have created the forum-thread category “server-config” (DC often calls these relays, for good reason, but people seeking help mostly call them servers).
Ah got it.. it has to be changed in both the files(chatmail.im|dovecot.conf). This isn’t a Debian Chatmail install.. I have it set up on FreeBSD. Thanks for the assist :>
