I would like to know if it is possible to insert some type of code that allows the automatic multimedia file compression, because in some services the sending of images, audios and files is too expensive for DC users …
For me and other Cubans, a good size is less than 50KB, but seems like the DC compression is about 100-200KB.
Options for the compression level would be really appreciated!
it seems to me that the user should be given the possibility to choose the size and quality of the file to be shared as other applications do …
I mean that if you could enable something like in the image, that would allow you to regulate the quality and size of multimedia files
