Hey guys,
DC 0.950.0 shows the wrong time in message details. It looks to me as if my phone uses the correct timezone wherease the message details use the GMT… see screenshot…
Next big bug:
After several hours oft inactivity the DC app crashes permanently whenever i try to reopen it. There is no Chance to restart it: neither killing the app nor restarting the phone could help.
Even deleting the app, reinstalling and reimporting the backup doesn’t help.
Looks to me as if the DC chat app datas are corrupt…
I use 64bit, 0.950.0 with Android 9
yip, the message details currently show UTC, that should be changed, indeed.
does a new install without using a backup work for you?
i did a pr here: https://github.com/deltachat/deltachat-core-rust/pull/815 - @ewo thanks for reporting!
Yes, but I found an even easer way: deleting app-data helps too. You just need to reimport your keys afterwards…
Here you see some screenshots of the bug:
… unfortunately all your conversations etc. are gone
… but you can start DC again ![]()
Greetings,
EWO
