Deleting Delta Chat's e-mails on server without deleting messages in Delta Chat
Is it possible to make Delta Chat delete it’s e-mails in the inbox on the server after it receives the messages? The messages in Delta Chat should stay. But the e-mails which contain those messages should get deleted after receiving. Because I don’t need those service e-mails. There are more of those e-mails lingering there than total messages even. I use only one Delta Chat client. So there is no need to keep them.
If you use a chatmail account, incoming messages will be purged after about 14 days by your server.
If you only use a chatmail account with a single device, Delta Chat is supposed to delete all messages from the server after reception. If you used the backup feature in the past, this toggle might have switched, you can disable multi-device mode under advanced settings.
See similar topic Latent change in server settings [delete messages from server].
There was a dedicated options for it but it was recently removed: Remove delete_server_after config · Issue #8195 · chatmail/core · GitHub.
