Delta Chat on TAILS
Has anyone managed to run DC on a TAILS install in Persistent mode?
I have followed the 4 step guide from this forum, and the app runs OK, but returns a “connection refused: error OS 111” message when trying to establish a link.
Any ideas greatly appreciated.
The guide is available on
Maybe try socks5://127.0.0.1:9050 instead of socks5://localhost:9050.
I have just tried, at least on non-tails Linux socks5://localhost:9050 works with Tor for me.
Awesome. Works fine, thanks.
The only issue is, if you are trying to create a new, stealth, Profile, you have to choose the “USE OTHER SERVER” option, then “CLASSIC E-MAIL LOGIN” then the “+ Advanced” option, toggle “Use Proxy”, and fill in the SOCKS5 proxy details there. It took a bit of fiddling but eventually worked. And, the settings are Persistent.
This is great because Session’s LOKINET doesn’t work with TOR, Signal is useless without a SIM and, the pre-loaded PIDGEN is horrible and vulnerable to attacks.
Well done Delta Chat team, a great addition to my tinfoil-hat existence.
And, thanks to link2xt. Cheers.
Proxy settings should be outside of the login settings. This is already done on Android, but not on Desktop:
Yeah, I noticed the difference between my LineageOS Samsung s9 and the Linux version’s of DC. Cheers.
The above procedure has changed.
DC have relocated the proxy settings from the +Advance subsection to the top right option stack of the Main profile creation screen.
Much easier, cheers.
