DeltaTouch: Help testing the upcoming 2.9.0 release
This is a feature request.
DeltaTouch removed key-export menu items around version 1.10, presumably following the Android client design. I’ve just found out that the Android GUI key export options were removed due to an Android-specific security problem. On mobile Linux, it would be possible to export public and private keys (including public keys of contacts) directly to a keyring, which really ought to be more secure than an Android “Downloads” folder. :slight_smile:
Importing the public keys of contacts from the keyring could also be much slicker than creating .asc files and loading them into a chat, especially for larger numbers of contacts.
Minor UI papercuts:
Leftwards swipe message> hamburger menu> Copy text does not actually copy the text; you get another menu (the popup) and have to press a second button marked “Copy” to actually copy it.
When you want to remove a message from the Saved Messages, you have to swipe rightwards, click on the red refuse container, and answer “Delete one message on all your devices?” with “Delete for me”. In fact, this only removes the message from the saved messages; it does not delete instances of it elsewhere. “Delete one message from [chat name] on all your devices?” might be clearer.
Thanks for reporting, I created an issue.
I can bring back the key export function, but I’m not sure whether direct export to a keyring is feasible right now.
Are you aware of any app that already does this?
Well, that’s on purpose :grimacing: It’s a compromise that has to do with being able to select only a part of the message text, the swipe thing of Lomiri UI Toolkit and DeltaTouch aiming to work both on mobile and desktop linux, see here for background. I’m open for better solutions.
Do you mean when you have saved a message so that the bookmark icon appears? I think at least DC Android will show the same behaviour and strings as DeltaTouch in this case.
Yes, most Linux mailclients that do encryption. If you wish to encrypt an email to alice@example.com, they will use any public key for that address found in your keyring (often by default, but asking for confirmation with a popup). For instance, Claws, KMail and Neomutt all interact with a keyring like this. I think Evolution does. Keyrings usually have extensive command-line functionality, too.
Actually, mailclients interacting with keyrings seemed sufficiently standard that I assumed it would be fairly easy to implement, not much harder than key export to file. But either would be pretty useful and not really much less secure than the DB.
Maybe relabel the “Copy text” button to say “Select and copy” or “Copy or react” or something? Then the user would expect another menu.
Yes, I mean that. Okay, I’ll suggest it for the other clients. EDIT: Done!
And thank you for creating the URL recognition issue and for being, if anything, too responsive to my comments. I need to more clearly distinguish between when I am just mildly astonished by the UI (possibly just because it’s got a skiamorph) and when something is actually malfunctioning.
When editing a message one cannot remove or replace any attachments. This is mildly inconvenient, though I suppose one could accidentally send an extremely inappropriate attachment.
On the account setting labelled: “If read receipts are disabled, you won’t be able to see read receipts from others”, I think you are right that this is less clear in English, and “you also won’t” would be clearer. Labelling the setting “Neither send nor request read receipts” would be shorter and clearer.
Separately, while the setting seems to disable sending receipts, it seems I am still receiving them (both from people using other versions of Deltatouch and from other Deltachat clients).
This didn’t seem illlogical. Not telling someone (and eavesdroppers) you’re online and reading their messages is useful, but ignoring them when they tell you they are online does not improve anyone’s privacy. But I don’t know if I am requesting the receipts. I’d prefer receipts off by default, also to halve to number of messages, but I can see the opposing argument.
Finally, two truly trivial cosmetic issues. If the last message sent was to chat which was formerly the oldest (bottommost), that chat correctly moves to the top, but the horizontal rule under that chat goes missing. And horizontal and vertical centering of Latin characters and emojis in avatars is conspicuously off.
So no new serious issues.
It’s the same as in the official clients. Message editing is a feature of the core, and it’s for the text part of the message only for now. If you have sent an inappropriate attachment, just delete the message for everyone.
The strings are from the official clients, so it would be a general suggestion applicable to all clients.
When you disable the setting, future messages that you send out won’t request read receipts. Messages you have already sent out before changing the setting will continue to receive receipts. Does that match your experience or do you receive receipts for messages sent after disabling the setting?
Not sure I fully understand, but except for exposing the setting in the UI, all the read receipt stuff is handled by the core anyway, so nothing that can be changed in DeltaTouch.
I noticed this and thought I fixed it a long time ago. Obviously the “fix” does not work on platforms other than Ubuntu Touch. I believe that it’s an upstream bug in Lomiri UI Toolkit that will be hard to work around if the fix I already applied is not enough. I’ve created an issue in the DeltaTouch repo, but will likely have to move it to the Lomiri repo.
I’m telling QML to center the char in the avatar. Seems that doesn’t always work, but not sure whether there will be capacity to fix this soon.
As mentioned before, I’m very grateful that you are reporting all these things. It may take a while until it will be fixed in the app in many cases though - hope you understand.
Sorry, just found this unsent in my drafts:
Deleting the message would make sense. I tried it, it works. I suppose I didn’t think of it because it is not in the leftwards-swipe or edit-message menu. Thanks.
I made a feature request for the read receipt phrasing.
The vertical centering in the avatars in QR codes is most conspicuous; in chat I think they’re good enough. EDIT: I think the centering is fine now
I am am not worried if things take a long time, especially when they are so minor I’m not sure I’d bother fixing them.
