Dev: unit tests failing on current commit without any change
Disclaimer
Hello there o/ This is my first post here, so if I got the category wrong, or can improve in any way, please tell me.
commit:36a480fec8ca23dbbbd490b76d485616f3591e28
Operating System
linux
unit tests passing
1 unit test failing
  1. Checkout current HEAD (36a480fec8ca23dbbbd490b76d485616f3591e28)
    of the deltachat-core-rust repository
  2. run $ cargo test
Debug logs
failures:
---- oauth2::tests::test_oauth_from_mx stdout ----
thread 'oauth2::tests::test_oauth_from_mx' panicked at src/oauth2.rs:411:9:
assertion `left == right` failed
  left: None
 right: Some(Oauth2 { client_id: "959970109878-4mvtgf6feshskf7695nfln6002mom908.apps.googleusercontent.com", get_code: "https://accounts.google.com/o/oauth2/auth?client_id=$CLIENT_ID&redirect_uri=$REDIRECT_URI&response_type=code&scope=https%3A%2F%2Fmail.google.com%2F%20email&access_type=offline", init_token: "https://accounts.google.com/o/oauth2/token?client_id=$CLIENT_ID&redirect_uri=$REDIRECT_URI&code=$CODE&grant_type=authorization_code", refresh_token: "https://accounts.google.com/o/oauth2/token?client_id=$CLIENT_ID&redirect_uri=$REDIRECT_URI&refresh_token=$REFRESH_TOKEN&grant_type=refresh_token", get_userinfo: Some("https://www.googleapis.com/oauth2/v1/userinfo?alt=json&access_token=$ACCESS_TOKEN") })
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
========== Chats of 2803061939: ==========
2803061939 WARN: src/provider.rs:250: Cannot resolve MX records for "youtube.com".
---- securejoin::tests::test_setup_contact_wrong_alice_gossip stdout ----
thread 'securejoin::tests::test_setup_contact_wrong_alice_gossip' panicked at src/securejoin.rs:870:9:
  left: true
 right: false
========== Chats of bob: ==========
Single#Chat#10: alice@example.org [alice@example.org]
Msg#11: info (Contact#Contact#Info): Establishing guaranteed end-to-end encryption, please wait… [NOTICED][INFO]
Msg#12: info (Contact#Contact#Info): Could not yet establish guaranteed end-to-end encryption, but you may already send a message. [NOTICED][INFO]
========== Chats of alice: ==========
Single#Chat#10: bob@example.net [bob@example.net]
bob Received Event { id: 2464967561, typ: ConfigSynced { key: Displayname } }
alice INFO: src/securejoin.rs:128: Generated QR code.
alice Received Event { id: 784339124, typ: ConfigSynced { key: Displayname } }
bob INFO: src/securejoin.rs:163: Requesting secure-join ...
bob INFO: src/contact.rs:932: Added contact id=10 addr=alice@example.org.
bob Received MSGS_CHANGED(chat_id=Chat#Special0, msg_id=Msg#0)
bob Received Event { id: 2464967561, typ: ChatlistChanged }
bob Received Event { id: 2464967561, typ: ChatlistItemChanged { chat_id: Some(ChatId(10)) } }
bob INFO: src/mimefactory.rs:1171: Sending secure-join message "vc-request".
bob Received MSGS_CHANGED(chat_id=Chat#10, msg_id=Msg#11)
alice INFO: src/receive_imf.rs:221: Receiving message "Mr.Wsae7Jd_lAg.crM9kTB7zgU@localhost", seen=false...
alice INFO: src/contact.rs:932: Added contact id=10 addr=bob@example.net.
alice INFO: src/securejoin.rs:295: Received secure-join message "vc-request".
alice Received Event { id: 784339124, typ: SecurejoinInviterProgress { contact_id: ContactId(10), progress: 300 } }
alice Received MSGS_CHANGED(chat_id=Chat#Special0, msg_id=Msg#0)
alice Received Event { id: 784339124, typ: ChatlistChanged }
alice Received Event { id: 784339124, typ: ChatlistItemChanged { chat_id: Some(ChatId(10)) } }
alice INFO: src/e2ee.rs:66: Peerstate for "bob@example.net" is mutual.
alice INFO: src/mimefactory.rs:1171: Sending secure-join message "vc-auth-required".
alice INFO: src/chat.rs:1352: Set gossiped_timestamp for chat Chat#10 to 1723999356.
alice Received CONTACTS_CHANGED(contact=Some(ContactId(10)))
bob Received MSGS_CHANGED(chat_id=Chat#10, msg_id=Msg#12)
bob Received CHAT_MODIFIED(Chat#10)
failures:
test result: FAILED. 835 passed; 2 failed; 1 ignored; 0 measured; 0 filtered out; finished in 89.44s
Discussed here: Dev: unit tests failing on current commit without any change · Issue #5878 · deltachat/deltachat-core-rust · GitHub
