Does Delta Chat support TLS 1.3
Hi,
I run a dovecot IMAP server configured to allow TLS 1.3 only. Delta Chat fails to login unless I allow TLS 1.2 as well (log snippet attached). Since my dovecot config works well with other mail clients I wanted to ask whether Delta Chat does support TLS 1.3 at all (especially on iOS).
However, the dovecot log indicates that TLS 1.3 is not supported.
Pardon me if this question has been answered somewhere else. I cloudn’t find anything on Github or here.
v.1.32.0 (iOS)
Delta Chat successfully perfoms the TLS handshake
IMAP login fails
  1. Configure dovecot with ssl_min_protocol = TLSv1.3
  2. Try to log in with Delta Chat
Debug logs
Logs
dovecot: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 0 secs):
Delta Chat: Error: error code -9806
We created an issue for this
Chatmail relays are also configured to only accept TLS 1.3: Require TLS 1.3 on client-facing ports by link2xt · Pull Request #454 · chatmail/relay · GitHub
So TLS 1.3 is definitely supported in Delta Chat, likely since switch to Rustls library.
