Hello!
I’m trying to deploy a chatmail relay and am getting very close! I have run into this error message when running scripts/cmdeploy test:
Long Error Message
[gw1] [ 94%] FAILED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_no_vrfy
================================================================ FAILURES =================================================================
______________________________________________________________ test_no_vrfy _______________________________________________________________
[gw1] linux -- Python 3.12.3 /home/user/relay/venv/bin/python3
cmfactory = <cmdeploy.tests.plugin.ChatmailACFactory object at 0x71154264d820>
chatmail_config = <chatmaild.config.Config object at 0x711543f30d10>
def test_no_vrfy(cmfactory, chatmail_config):
ac = cmfactory.get_online_account()
addr = ac.get_config("addr")
domain = chatmail_config.mail_domain
> s = smtplib.SMTP(domain)
cmdeploy/src/cmdeploy/tests/online/test_0_login.py:97:
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
/usr/lib/python3.12/smtplib.py:255: in __init__
(code, msg) = self.connect(host, port)
/usr/lib/python3.12/smtplib.py:341: in connect
self.sock = self._get_socket(host, port, self.timeout)
/usr/lib/python3.12/smtplib.py:312: in _get_socket
return socket.create_connection((host, port), timeout,
/usr/lib/python3.12/socket.py:852: in create_connection
raise exceptions[0]
address = ('chatmail.example.com', 25), timeout = <object object at 0x71154b178aa0>, source_address = None
def create_connection(address, timeout=_GLOBAL_DEFAULT_TIMEOUT,
source_address=None, *, all_errors=False):
"""Connect to *address* and return the socket object.
Convenience function. Connect to *address* (a 2-tuple ``(host,
port)``) and return the socket object. Passing the optional
*timeout* parameter will set the timeout on the socket instance
before attempting to connect. If no *timeout* is supplied, the
global default timeout setting returned by :func:`getdefaulttimeout`
is used. If *source_address* is set it must be a tuple of (host, port)
for the socket to bind as a source address before making the connection.
A host of '' or port 0 tells the OS to use the default. When a connection
cannot be created, raises the last error if *all_errors* is False,
and an ExceptionGroup of all errors if *all_errors* is True.
host, port = address
exceptions = []
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
af, socktype, proto, canonname, sa = res
sock = None
try:
sock = socket(af, socktype, proto)
if timeout is not _GLOBAL_DEFAULT_TIMEOUT:
sock.settimeout(timeout)
if source_address:
sock.bind(source_address)
> sock.connect(sa)
E OSError: [Errno 101] Network is unreachable
/usr/lib/python3.12/socket.py:837: OSError
=========================================================== slowest 5 durations ===========================================================
138.29s call src/cmdeploy/tests/online/test_0_login.py::test_no_vrfy
13.51s call src/cmdeploy/tests/online/test_1_basic.py::test_expunged
13.04s call src/cmdeploy/tests/online/test_1_basic.py::test_exceed_rate_limit
11.55s call src/cmdeploy/tests/online/test_0_login.py::test_concurrent_logins_same_account
10.05s call src/cmdeploy/tests/online/test_1_basic.py::test_reject_missing_dkim[fake@testrun.org]
========================================================= short test summary info =========================================================
SKIPPED [1] cmdeploy/src/cmdeploy/tests/online/test_1_basic.py:126: set CHATMAIL_DOMAIN2 to a second chatmail server
SKIPPED [2] cmdeploy/src/cmdeploy/tests/online/test_1_basic.py:178: port 25 not reachable for chatmail.example.com
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! stopping after 1 failures !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! xdist.dsession.Interrupted: stopping after 1 failures !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
=========================================== 1 failed, 69 passed, 3 skipped in 153.73s (0:02:33) ===========================================
I notice that it says port 25 not reachable for chatmail.example.com but I have checked that port 25 is open on the firewall and have also tried disabling the firewall, both with the same result.
My VPS host has allowed for outbound traffic on port 25 and 465 and I’m running this on a fresh Debian 12 deployment.
Does anyone have any suggestions for other troubleshooting steps or solutions?
Thank you!
