🧪 Help testing the upcoming 1.29.X release
The time has come for a new Desktop Release! :tada: Help us find the most
annoying bugs so we can make sure this update is ready to be released on
the website and in stores. :flexed_biceps:
Release Highlights
:man_running: Jump to a message from gallery view
:framed_picture: Quote messages with images or gifs
:hamburger: New hamburger menu sidebar
:open_file_folder: Expandable settings dialogue
:keyboard: Keyboard shortcut cheatsheet accessible via Ctrl + / or Cmd + /
:raised_fist: New videochat instances available. Check out the aussum work of collaborating
projects https://www.systemli.org/ and https://www.autistici.org/
Apart from many bugfixes this release contains a new hamburger menu sidebar
and expandable settings. Please tell us how you like the new interface,
what you think is intuitive and where you had a hard time looking for an
option.
What to test?
  • Menu sidebar and settings
  • Jump to message from gallery
  • Quote/reply to message with attached image or gif
  • MessageList (the area where you scroll though the messages of a chat)
  • New account
  • Export Backup
  • Normal usage
  • Zoom in Gallery
  • Jump to message from search
  • Download message on demand (set download limit in settings, then recieve
    a big file and click on download)
Click here for full change log
Where to report Bugs?
You can find already known bugs on: GitHub · Where software is built
Please report the found bugs either here in this forum topic or even better
as issue on GitHub: GitHub · Where software is built
Download
~~1.29.0: https://download.delta.chat/desktop/v1.29.0/~~
1.29.1: https://download.delta.chat/desktop/v1.29.1/
Important: please backup your current setup (or most important accounts)
before upgrading in order to be safe when trying test-releases. You can
find this option under Settings > Chats and Media > Backup.
Hallo,
beim Start unter MacOS 12.3.1 (M1), erscheint kurz diese Fehlermeldung:
Failed to start IO: scheduler is already stopped
Das Programm funktioniert aber bislang völlig problemlos.
Die neue Version wirkt auf mich wesentlich übersichtlicher.
Links ein neues Menü zu platzieren war eine gute Idee.
Mir erschien es immer unlogisch, dass früher die Einstellungen über das rechte Menü aufgerufen werden mussten, da sie sich auf das ganze Programm beziehen und nicht nur auf einen Chat.
Ich finde DC könnte noch etwas aufgeräumter wirken, wenn die Sidebar die ganze Chat-Liste überdecken würde.
Damit die Sidebar dann nicht zu leer wirkt, müsste eventuell das Profilbild vergrößert und zusätzlich noch die Signatur angezeigt werden.
Das neue Einstellungen-Menü gefällt mir ebenfalls gut.
Es ist sehr übersichtlich und man muss kaum noch scrollen.
Die animierten Tasten sind ein schönes Detail.
Für MacOS-Nutzer wäre es praktisch, wenn die Einstellungen auch über die Menüleiste aufgerufen werden könnten.
Das ist die Fehlermeldung:
Da wird wahrscheinlich auch noch mehr reinkommen später, mit der minimal höhe siehts aber auch nicht allzu leer aus gerade:
In welchem Reiter würde es denn am Besten passen?
Stimmt. Meinte nur, wenn man die Sidebar so verbreitern würde, dass die Chat-Liste darunter ganz verdeckt wird. Würde meiner Meinung nach etwas schöner aussehen.
Ist nur eine Geschmackssache.
Ich denke am besten in den DeltaChat-Reiter unter dem Punkt “Über Delta Chat”.
Die ChatListe soll in zukunft in der breite variabel sein, das wäre aber glaube ich komisch in kombination mit einem gleich großen sidemenu
Merci! Sollte in der nächsten Version drin sein, hier der fix: Show settings in menu on mac by Jikstra · Pull Request #2741 · deltachat/deltachat-desktop · GitHub
Ok, wußte ich nicht. Das wäre dann wirklich ungünstig.
Danke :+1:
A wild test release appeared!
version 1.29.1 is out for testing:
Added
  • Show settings menu item in titlebar menu
  • Sidebar closes on escape key
  • add chat name to webxdc window title
  • support for webxdc document names
  • Access archived chats through sidebar
Fixed
  • Fix crash on migrating accounts from an older version (before 1.21.0)
  • Add a guard against selecting accounts with impossible ids (smaller than 0)
  • Fix stock translations set too late (after I/0 is started) #2735
  • Fix jumping to send video chat invitation
  • Fix jumping to last message if sending multiple attachments through drag&drop
  • prevent webxdc content from setting the window title
  • Fix truncating of names and emails
Changed
  • Update @deltachat/message_parser_wasm to 0.4.0 (fixes a email parsing issue)
  • Update deltachat-node to v1.83.0
Hallo, :wave:
bisher sind mir nur zwei kleine Bugs aufgefallen.
In der Beschreibung zur Version 1.29 steht:
Bei mir unter MacOS 12.4 funktioniert nur Ctrl + /.
Im Shortcut-Sheet ist ausschließlich Cmd + / angegeben.
Der zweite Bug betrifft das Exportieren von Backups.
Nach der Auswahl eines Verzeichnisses muss man auf “Öffnen” klicken.
Es müsste aber “Speichern” heißen.
Während des Testens hatte ich zwei Ideen, wie die Bedienung noch etwas verbessert werden könnte:
  • Nachdem dem ein Backup erstellt wurde, wird eine grüne Bestätigung mit dem Dateipfad eingeblendet. Diese Meldung verschwindet nicht von alleine und muss durch einen Klick auf diese geschlossen werden. Ich finde man sollte das durch eine entsprechende Schaltfläche signalisieren.
  • Ein Pfeil mit dem man im Chatverlauf zur neuesten Nachricht zu springen kann.
Dankeschön :slight_smile:
Merci, ich schaue ob ich die sachen für die 1.30 gefixt bekomme :slight_smile:
Yes!
Das ist geplant für den nächsten entwicklungszyklus :slight_smile:
Thanks for testing everyone, we now started releasing 1.30.0:
thanks for new videochat instances support.
