How can I set default SMTP and IMAP details automatically?
Hi there!
I want to set default values for imap and smtp to a particular mail server and fetch the usernames and passwords from the AD on a different server, so that the log in process through “Classic E-Mail Login” is automated for all the users on the network (I dont want them to use the advanced settings option to log into their sogo account). I have installed DC as a flatpak on linux. Is there a way for me to do this? Please help me out! Thankyou : )
It’s not supported officially, but if you know programming then you can fork Deltachat-Desktop and change the login screen to automatically fetch from the AD server and log in. Then you can build an AppImage out of it and serve this to your users.
The question is probably not about using AD to fetch contacts, but about having an email server that uses AD as an authentication backend. For this there is no need to change Delta Chat.
It should be enough to write a https://autoconfig.example.org/mail/config-v1.1.xml file according to the specification draft-ietf-mailmaint-autoconfig-03 - Mail Autoconfig to make autoconfiguration work.
