Improve color contrast for links [in dark mode]
The color contrast for links can be improved especially with dark mode, light blue on gray is difficult to read! Normal text has good contrast with white on gray, but the links are a problem for the eyes!
Links have high contrast to read easily
Links have low contrast similar to background color
The link color was changed to blue here:
While the links are difficult to read in dark mode under normal conditions, they are really impossible to read if you are in a setting with bright light (outdoors in the sun) or if you have the screen dimmed.
I was reminded of this recently when I wrote a phone number in a message to a friend. I wanted to read the number again to double check I sent the correct number, but the phone number was automatically converted to a link and with the low color contrast of blue on gray I could not read the number at all without bringing my phone very close to my face. But obviously this is not great UX! I could read all the other text in the message and the UI elements without any problem, only the phone number which displayed as a link was unreadable.
I expect that some user testing with the colors and readability of links would confirm this is a usability issue.
  1. Switch to dark theme
  2. Dim the screen or go outside in the sun
  3. Write a message with a link or some text which will convert to a link
  4. Try to read the link
I regularly use devices outside in the sun. I turn the backlight up and switch to a bright, high contrast, almost monochromatic color scheme to facilitate this.
Switching to high contrast theme does help but this is in the accessibility settings and ideally it should not be necessary to search for settings in the phone’s accessibility settings simply to read links in the app, if accessibility settings aren’t needed otherwise and normal text can be read fine without accessibility settings!
I used the example of reading in the sun to demonstrate how unreadable the links are in an extreme case, but even under normal lighting conditions the color contrast is very poor, and it can be improved a lot.
I will also point out that even in the sun I can read the normal text without problems, so the problem is specifically the color which Delta Chat uses for the links with dark mode. I think the best solution (and easy to implement) is Delta Chat uses colors with higher contrast for the links, instead of users needing to turn on high contrast theme in the phone’s accessibility settings.
