Install kills phone network needs restart
Don’t know - can’t get it to work
Nothing
It kills my phone’s network. I have to restart the phone after installing.
  1. In google Play install Delta Chat
  2. Network access from phone no longer works. Can’t access network for anything.
  3. reboot phone.
SOLVED: Problem caused by use of VPN
Wow this is efficiency.
No one has had time to answer you and you have already solved! :sweat_smile::tada::confetti_ball:
