Issues Deploying Chatmail Server on AWS – DNS Settings Help Needed
I’m trying to deploy the Chatmail server on AWS and encountered a few issues along the way:
  1. crypt-r replaced with crypt – I found a similar issue here, so that’s sorted.
  2. SSH-related issues – Managed to fix them, and another way to deploy is from the same localhost.
  3. Now stuck with DNS settings problems.
Has anyone successfully deployed Chatmail on AWS? Any guidance on DNS settings would be greatly appreciated. Thanks!
I also stumble into some problems as a first-time self-hoster but in another VPS provider, but maybe this also applies to you:
I successfully deployed and ran the ChatMail server on AWS after AWS lifted the port 25 restrictions. Here are a few key steps I had to take on AWS for deployment:
  1. Request access to SMTP port 25.
  2. Ensure root access (AWS default user is ubuntu).
  3. Enable outgoing SMTP (25) and SMTPS (465) ports, as well as inbound IMAP (143) and IMAPS (993) ports.
  4. Configure rDNS on your elastic IP.
  5. Verify that port 25 is unblocked using telnet <domain.com> 25. Note that telnet localhost 25 may work, but DNS propagation could take time, so allow it to complete.
Other than that, the deployment process was quite straightforward. Simply follow the commands in the README:
$ git clone https://github.com/chatmail/server.git
$ cd server
$ scripts/initenv.sh
$ scripts/cmdeploy init chat.example.org  # <-- use your domain
$ scripts/cmdeploy run
DNS entries look as:
my-server.com.                   MX 10 my-server.com.
_mta-sts.my-server.com.          TXT "v=STSv1; id=2025023471600"
opendkim._domainkey.my-server.com. TXT "v=DKIM1;k=rsa;p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAwrACM/0v3y+jAQXpKXUvA4GDFopPs7tzH73qvo9USainyYzEhNCisc38B+gROvMPPRcqSUU2z4eODdadKcleJhfiPS1P+DJWaAmoRH6c0l14fl+njvGug9R/yrkG45+DJWaAmoRH6c0l14fl+njv" "Gug9R/yrkG45uKtkYiMsHfSGUU+HOfNQGJpNgLaCzBLKOCBElSdDFPr2NWA7L+sVeh/CGT7U7X15UseKUuaZ4MWwz9q+XKzv+xXMJDbhk+wfgZ/AdtSKcXMIgJQH9D8o+YExZYQrW5yXB2rnkowIDAQAB;s=email;t=s"
If the DKIM entry above does not work with your DNS provider, you can try this one:
opendkim._domainkey.my-server.com. TXT "v=DKIM1;k=rsa;p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAG9w0BAQEFAAOCACM/0v3y+jAQXpKXUvA4GDFopPs7tzH7NNgbdG9w0BAQEFAAOCAh48xKqMcBqx9UPH5ZYdNUwr9yRdbdWwo+/tlF5ruJTpErbKoZaQTy3qvo9USainyYzEhNCisc38B+gROvMPPRcqSUU2z4eODdadKcleJhfiPS1P+DJWaAmoRH6c0l14fl+njvGug9R/yrkG45uKtkYiMsHfSGUU+HOfNQGJpNgLaCzBLKOCBElSdDFPr2NWA7L+sVeh/CGG9w0BAQEFAAOCAaZ4MWwz9q+XKzv+xXMJDbhk+wfgZ/G9w0BAQEFAAOCA+YExZYQrW5yXB2rnkowIDAQAB;s=email;t=s"
WARNING: these recommended DNS entries are not set:
my-server.com.                   TXT "v=spf1 a ~all"
_dmarc.my-server.com.            TXT "v=DMARC1;p=reject;adkim=s;aspf=s"
my-server.com.                   CAA 0 issue "letsencrypt.org;accounturi=https://acme-v02.api.letsencrypt.org/acme/acct/2025023471600"
_adsp._domainkey.my-server.com.  TXT "dkim=discardable"
_submission._tcp.my-server.com.  SRV 0 1 587 my-server.com.
_submissions._tcp.my-server.com. SRV 0 1 465 my-server.com.
_imap._tcp.my-server.com.        SRV 0 1 143 my-server.com.
_imaps._tcp.my-server.com.       SRV 0 1 993 my-server.com.
After installing the server, I noticed that it works for emails within the my-server.com domain but not for external addresses like Gmail or others.
Is this due to a missing configuration, or is it a limitation?
In fact quite a few tests are failing on running: scripts/cmdeploy test
[$ /root/server-large/server/venv/bin/python3 -m pip install deltachat]
Collecting deltachat
  Downloading deltachat-1.155.6-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (1.5 kB)
Requirement already satisfied: cffi>=1.0.0 in ./venv/lib/python3.10/site-packages (from deltachat) (1.17.1)
Requirement already satisfied: imap-tools in ./venv/lib/python3.10/site-packages (from deltachat) (1.10.0)
Requirement already satisfied: pluggy in ./venv/lib/python3.10/site-packages (from deltachat) (1.5.0)
Requirement already satisfied: requests in ./venv/lib/python3.10/site-packages (from deltachat) (2.32.3)
Requirement already satisfied: pycparser in ./venv/lib/python3.10/site-packages (from cffi>=1.0.0->deltachat) (2.22)
Requirement already satisfied: charset-normalizer<4,>=2 in ./venv/lib/python3.10/site-packages (from requests->deltachat) (3.4.1)
Requirement already satisfied: idna<4,>=2.5 in ./venv/lib/python3.10/site-packages (from requests->deltachat) (3.10)
Requirement already satisfied: urllib3<3,>=1.21.1 in ./venv/lib/python3.10/site-packages (from requests->deltachat) (2.3.0)
Requirement already satisfied: certifi>=2017.4.17 in ./venv/lib/python3.10/site-packages (from requests->deltachat) (2025.1.31)
Downloading deltachat-1.155.6-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (13.4 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 13.4/13.4 MB 2.4 MB/s eta 0:00:00
Installing collected packages: deltachat
Successfully installed deltachat-1.155.6
[$ /root/server-large/server/venv/bin/pytest cmdeploy/src/ -n4 -rs -x -v --durations=5]
===================================================================== test session starts =====================================================================
platform linux -- Python 3.10.12, pytest-8.3.5, pluggy-1.5.0 -- /root/server-large/server/venv/bin/python3
cachedir: .pytest_cache
Deltachat core=v1.155.6 sqlite=3.45.3 journal_mode=wal
rootdir: /root/server-large/server/cmdeploy
configfile: pyproject.toml
plugins: typeguard-4.4.2, deltachat-1.155.6, xdist-3.6.1, chatmaild-0.2, cmdeploy-0.2, deltachat-rpc-client-1.156.2
4 workers [45 items]
scheduling tests via LoadScheduling
cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_basic_functioning[imap]
cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_init
cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_same_password[imap]
cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_concurrent_logins_same_account
[gw0] [  2%] PASSED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_init
cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_capabilities
[gw0] [  4%] PASSED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_capabilities
cmdeploy/src/cmdeploy/tests/online/test_0_qr.py::test_gen_qr_png_data
[gw2] [  6%] PASSED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_same_password[imap]
cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_same_password[smtp]
[gw0] [  8%] PASSED cmdeploy/src/cmdeploy/tests/online/test_0_qr.py::test_gen_qr_png_data
cmdeploy/src/cmdeploy/tests/online/test_0_qr.py::test_fastcgi_working
[gw0] [ 11%] PASSED cmdeploy/src/cmdeploy/tests/online/test_0_qr.py::test_fastcgi_working
cmdeploy/src/cmdeploy/tests/online/test_0_qr.py::test_newemail_configure
[gw1] [ 13%] PASSED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_basic_functioning[imap]
cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_basic_functioning[smtp]
[gw3] [ 15%] FAILED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_concurrent_logins_same_account
[gw2] [ 17%] FAILED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_same_password[smtp]
[gw1] [ 20%] FAILED cmdeploy/src/cmdeploy/tests/online/test_0_login.py::test_login_basic_functioning[smtp]
[gw0] [ 22%] PASSED cmdeploy/src/cmdeploy/tests/online/test_0_qr.py::test_newemail_configure
cmdeploy/src/cmdeploy/tests/online/test_1_basic.py::TestSSHExecutor::test_exception
[gw0] [ 24%] PASSED cmdeploy/src/cmdeploy/tests/online/test_1_basic.py::TestSSHExecutor::test_exception
cmdeploy/src/cmdeploy/tests/online/test_1_basic.py::TestSSHExecutor::test_opendkim_restarted
[gw0] [ 26%] PASSED cmdeploy/src/cmdeploy/tests/online/test_1_basic.py::TestSSHExecutor::test_opendkim_restarted
$ scripts/cmdeploy dns
[ssh] login to my-server.com
Collecting initial DNS settings..............
Check expected zone file entries...........................................
Great! All your DNS entries are verified and correct.
produces following result:
Grand total        95      18        -       77
Looks like something wrong with the smtp? But my port 25 is unblocked, am i missing anything here?
this is how chatmail works, outgoing email is forced to be encrypted, in the future likely even between users in the same instance, for security reasons, otherwise the messages and documents are leaked in plain-text if you allow unencrypted, also besides security/privacy the main initial reason is to avoid abuse/spammers since accounts can be created without manual approval, enforcing encryption ensures no random spammer creates an account and starts spamming hundreds of users without restrictions getting your server blacklisted
you can always add exceptions in the chatmail.ini file if some admin or trusted person needs to send unencrypted to interact with classic email users
