I was using the Delta Chat with a legacy account relay. A while ago (about 2 years) I changed devices but kept the old device with Delta chat. Recently I add on this new device a new relay (since the legacy relay are not recommended). I was expecting the new relay to show up on the old device. But in fact what happened was that it didn’t and I still see the legacy relay on the old device.
I have since removed the legacy relay from the new device. But old device still shows legacy relay and doesn’t show the new relay.
I am considering on the old device add the new relay by adding as a secondary device and then remove the legacy relay. Is this the correct way to handle this?
Many thanks
I was expecting the new relay to show on the secondary device.
Secondary device doesn’t show the new relay.
- Using an account that uses the legacy relay
- Create a new account
- Open the secondary device
- Observe that the new relay is not there
