How do I get the encryption key from Delta into Mailvelope? Mailvelope: PGP for Gmail & Webmail
I have the autocrypt setup message from Delta. Now what? Mailvelope has an import key feature. But importing the autocrypt setup message doesn’t work.
hi @Guithay - first, welcome aboard!
to your question: development of Autocrypt support for Mailvelope has started - which are great news
- however, i do not know what the exact state is and if there is already a release available and how the import-processing of the setup-message will be done.
as an alternative, however, you can export your private key as an .asc file in delta chat (at settings / advanced) and copy it manually to the Mailvelope device and import it there (probably using the option you’ve mentioned above)
