Valued team, developers, user
…trusting that such “experiments” for possibilities are welcome…
When ever inspired to back on this feed, or to play forward, all hints, links, tips and edits in relation of the topic are welcome, even musing about it’s use or it’s not use in daily life.
From an manual draft, disscussion here: https://support.delta.chat/t/comprehensive-manual-for-dc/
That option can be also reached via the chat-menu. If you feel to much disturbed by a chat’s messages, instead of thinking to leave a group (since not easy to join again without a member adding you), one has the possibility to mute chats. No notifications would be arising for chosen time.
An icon would appear in the profil-headerand in the chat-list as well.
This settings can be changed and unmute made in the chat-menu as well. Nobody would be informed and possible stressed about this “leave” for a while.
Reflections: Never used such, maybe because merely one tending to cause notificatiins, but a great alternative to mood reactions of leave a group or topic behind since moods are not for sure and desired birth not sure to be gainable. Handy option and clearly developed by those under attacks of countless notifications, right good master @r10s ?
