Messages do not appear
Hi,
Since I started to use DC the messages do not appear on other webmail clients.
How to change this behavior? Is it possible to see and access messages on different clients?
Hi,
Did you check if there is a DeltaChat folder in your other client, it should be there if not in inbox.
Now is appearing. It was needed to turn able the folder.
Tks
