Monitor Chatmail usage
Hi,
I just played around a little with a chatmail server and got it running.
Now I wonder how I can monitor the usage. Of course nothing invasive, just the number of accounts and the numbers of in- and outgoing messages.
I already tried the solutions I found on the internet but could not find any logs or receive other information about the status.
I installed the chatmail server on a Debian 12 VPS.
Dex
Some basic metric on the number of accounts is exposed at /metrics, e.g. https://bcc.chat/metrics
This I would like to remove at some point Remove `/metrics` · Issue #431 · deltachat/chatmail · GitHub but currently it exists.
For better monitoring there is mtail service. You can configure it by setting mtail_address = 127.0.0.1 and redeploying, then you can run curl http://127.0.0.1:3903/metrics on the server to get the metrics. These metrics are in OpenTelemetry format so can be polled by Prometheus, but Prometheus/Grafana/etc. you need to setup manually.
You can also see number of currently connected accounts by running doveadm who | wc -l on the server.
Großartig, vielen Dank!
