New feature: Group Types
key rotation is complicated, if one member doesn’t receive the message with the new key they will not be able to read the group anymore, as I already mentioned in the other thread, it is better to keep things simple:
  • group with owner is mainly for public groups and there it doesn’t matter key is fixed,
  • private groups don’t need owners and there message is encrypted to members and not with fixed key
Would key rotation be easier in the “blind” groups? As in the owner could help co-ordinate the key rotation to provide many-to-many comms, not just 1-to-many.
it is the same problem, you have no warranty all your subscribers received the new key, so you can’t rotate, you could implement some confirmation mechanism in which you pre-advertize the upcoming key but keep using the old one until all subscribers confirm they received the new key, but just one inactive member would delay the rotation potentially forever, plus such auto-reply/confirm mechanism for subscribers have privacy considerations
it is a blind group == channel, key rotation is not needed, it is probably public channel, if used privately for people you trust then it doesn’t matter
It will be easier without this confirmation part.
Admin adds a second key, and in a couple of days/weeks drops the first one.
that would cause “unable to decrypt” experiences, which is not acceptable
Am I correct in understanding that newly added group members won’t see previously published messages in the group? Is this the same for channels?
yes.
yes.
for groups, this is can be regarded as a privacy feature. however, reason is also that it is just not done and not easy :slight_smile: still, one can resend one own’s messages after a member is added.
since the rest is already done, it makes sense to have a dedicated on-point topic, I created it at:
to recapitulate this was the latest state of the proposal for “Owned Groups”:
let’s close this topic and continue the discussion about “Owned Groups” (a.k.a Super groups) in the other thread
