Quality measure in mini app picker
Currently, the apps in the mini app picker are ordered by recently added and there are many apps to choose from.
It’s impossible to see what apps are good at a first glance from description alone. This leads to disappointment in the app and in DC mini apps in general.
Possible Measures to improve it:
A. A Badge for tested quality apps that follow some standards like having collaboration when you’d expect it and having nearly no bugs.
B. Have a featured apps tab that only shows presentable mini apps, to get a good first impression by new users
C. Rating system with stars
D. allow users to have a list of their favorite apps (this was already suggested in another post, but discourse search is so bad that I can’t find it)
Suggested Metrics for apps
  • Does the core functionality work?
  • If you already see it was low effort by many bugs, then that is bad.
  • Are webxdc features used where you would expect it?
    • chess app should have multiplayer, editor, todo lists and collaboration tool should have collaboration
    • tool apps without persistent state, like some unit converter on the other hand don’t need collaboration
  • Is UX clear to nice to use?
  • is the design consistent?
The AI vibe-coded apps might add to the problem, but remember there were low effort apps long before vibe-coding even was a thing.
I suggested the star system in this post WebXDC app store idea: GitHub search wrapper page. Good news: yours and mine apps take the top 2.
I think hosting a user-controlled rating system for this is overkill. Displaying the number of stars on the repository will bias the results based on the size of the forge and the number of developers using the given app (as normal users rarely have an account on such forge).
It would be perfectly sensible if the curator of the given app store listing just added static ratings themselves. A “Featured” tab is just a binarization of this, but it would work just as well to give 1-5 stars in the same way.
The ratings of the curator could be stored in the same structure where other curated tags could be also added as mentioned here:
As a more objective alternative instead of the star rating, the curator could tag an app with each aspect that you mention above such as whether there remain any known, but unfixed bugs or not (even list them in a small textual note?). I have already proposed tags to mark the scale of interactivity in a given app.
I can’t provide guidance about how to note UX & design issues, but I guess the more grave ones could be handled as bugs.
Features that require maintenance are probably difficult to implement as the maintainers typically have enough things to do already. But adding more quality metrics to the store website seems like an easy way to improve on the current situation. Maybe just adding multiple ways to sort the app list by metrics that can be automated is enough? Personally, I would like to see ‘Last Updated’, ‘Repository Stars’, and ‘Downloads over the last 30 days’.
Unfortunately the AI coded apps are much higher quality than the human coded ones now…
In any case, I just recommend making your own App Store with exactly what you want. You can give that to new users, now that we can have custom app stores in the app.
