Restart the software loading speed issue
Restarting the deltachat connection on the phone is very slow, which should take a few seconds. Is there a better solution to this problem? Thanks
  • what email provider are you using?
  • Where are you based, are you near or far away from the email provider.
  • Define slow, how many seconds does it take?
