On multiple devices, if you delete the saved messages folder, you should have a method to recreate it. If recreated, you should be able to replace the icon back to the default one.
Saved messages is deleted from iOS but remains on macOS. When a message is forwarded on macOS into the chat, it recreates it correctly on iOS but the icon is your profile image, not the saved messages icon. There exists no method to change the icon.
As above
It would be nice to have a mechanism in each client under Advanced to recreate that chat if you delete it. That would probably be the easiest way to solve the above.
