if you want to use Delta Chat with another language than the system language on ios,
- in the global system settings, open “General / Language & Region” and make sure there are at least two preferred languages in any order
- if there are at least two preferred languages, you can select the language for Delta Chat in the global system settings at “Delta Chat / Language”
for whatever reason, this option is not available if you have only one preferred language
