SimpleBot public instances list
SimpleBot is a free/libre software, pluginable bot for Delta Chat written in Python, features depend on the installed plugins, think of it as a Lego robot. It is still a work in progress and isn’t well documented yet, but here are some instances running already:
To see the list of plugins a given bot support and the commands to use them, send a message to the bot with text:
/help
The source code can be found here:
Is it posible to start/use a bot for general DC releas informations?
there are an RSS plugin, you can subscribe to the release page of any github project, including DC core, DC android, DC desktop, etc
I can’t edit the post anymore, and it is outdated :frowning:
:hushed: Why?
Just send to simplebot the following commands.
For Android:
/feed_sub https://github.com/deltachat/deltachat-android/releases.atom
For iOS:
/feed_sub https://github.com/deltachat/deltachat-ios/releases.atom
For Desktop:
/feed_sub https://github.com/deltachat/deltachat-desktop/releases.atom
Are these bots open source? :heart:
Oh, they are! :heart:
Here is GitHub - simplebot-org/simplebot_mastodon: [WIP] Mastodon ↔️ DeltaChat bridge for example. Thank you, this is awesome!
Dear @anon76174457 that are public bots I setup to help poor Cubans to access Internet services through email which is cheaper in Cuba, you and your friends are welcome to use them and you can setup your own instances as well if you have some server/VPS or even a mini-PC where to run the bot
Hello :wave:,
could it be that all Hispanilandia.net bots are offline?
They haven’t worked for me for days.
I don’t use many bots but at least feedsbot@hispanilandia.net works smoothly for me
Unfortunately none works for me. :thinking:
Whenever I try another bot I get this error message:
Aborting previously unfinished QR Join process
It doesn’t matter how much time has passed.
After that, DC reports that it could not verify the bot.
Non-hispanandia.net bots work fine.
@adbenitez
Hello :wave:,
Hispanilandia.net bots haven’t worked for me for a while.
There is always a message that the bot in question could not be verified.
I’m not sure if the error is on the server side or with me. Other bots work just fine.
However, the hispanilandia.net bots also work without any problems for other users here in the forum. That speaks again to the fact that I must be doing something wrong.
Do you have any ideas what else I could try?
@Raiden hi, are you still having issues? please notice that in the “public instances list” page you can click the address to verify the bot but that is not mandatory, you can just write directly to the bot addresses, send /help to the desired bot it should reply,
btw I didn’t checked the forum in several weeks, I am mostly in email-only mode most of the time and don’t use too much the web, if you want to reach me and get faster responses from me, it is better if you join to the “Delta Chat community” super group (it is an anonymous mailing list tweaked to work as a Delta Chat super group smoothly, your email address is not exposed to the members of the group so it is safe to drop by, kinda an IRC-like channel with nicks inside Delta Chat) to join send to the bot groupsbot@hispanilandia.net a message with the text:
 /join_deltachat-community.hispanilandia.net
if that bot doesn’t reply to you then don’t hesitate to contact me directly writing to adbenitez@nauta.cu in that case it is probably that you are using an email server that is blocking hispanilandia.net and that is why you would not get any response from bots with @hispanilandia.net address
best regards,
adb :wave:
hi, check:
I don’t remember right now if I changed it, but by default I think it uses Google Translator
