About socks5 it says
socks5 support is …
Can you specify which leaks may occur?
What about running deltachat in combination
with torsocks or proxychains? Will that
get all data over tor? Thank you.
socks5 support is …
which map tiles you open in the desktop version for example, but mail traffic and dns should go over the socks5 connection. I guess proxychains would work, though I didn’t try it yet. You could look into it with Wireshark I guess?
