It should be easy to implement it at least to add unencrypted contacts. For encrypted contacts the QR code may be large because of the key inside and nobody generates such QR codes anyway.
I just checked the sizes of couple of DC generated vcards (for encrypted contacts, with keys).
If there is no picture, the size is usually around 700 bytes.
E.g. libqrencode manual says the capacity of QR Code is up to 4000 characters.
With embedded picture vcard size card can go up to 60+ kbytes (or even higher - I just tested small amount, and not looked ad DC app code).
IMHO it’s better to include the code and downscale the picture (and maybe encode it to PNG with reduced color pale) to fit into 4000 chars.
May I ask, what are the advantages over current vcard format?
An open standard for contact QR codes would be nice. I am not familiar with MeCards. They look decent except for the name field; of all places for software to make cultural assumptions about name ordering, Japan?
I think opgpcard produces QR codes of VCards containing key fingerprints and a keyserver link; you can also just omit fields. This makes them resonably compact – I’ve got one at 255 bytes – but the dependency on the server is undesirable.
It’s interesting to note that, actually, QR Codes can encode data more efficiently in some cases if only uppercase letters are used. That’s because it has a special encoding mode for text consistent of only (uppercase) letters, numbers, and common symbols. It may be advantageous to encode a URL like HTTP://MYSITE.COM/FOO… rather than http://mysite.com/foo… for this reason. However, this depends upon the web server responding to requests correctly when the URI is uppercased. It’s not necessarily true that URIs and paths are treated as case-insensitive by a web server, since URIs are technically case sensitive. Don’t try this unless you test it to know it works.
I didn’t think about the invite URL…
In example URL: https://i.delta.chat/#A1B2C3....99FFFF&a=username%40domain.tld&n=xxxx&i=yyYYyyYY&s=zzZZzzZZ
protocol and domain - IDK if is it case-sensitive in ‘custom URL handlers’ on mobiles; but desktop browsers (and probably mobile browsers too) opens HTTPS://I.DELTA.CHAT/ without problems
key fingerprint - uppercased already (BTW may be packet in shorter string with base64 or something)
username@domain.tld - also should be case-insensitive
n=, I=, s= options - probably case-sensitive, but maybe it can be created in uppercase.
Maybe mostly-uppercased URL will result in ‘shorter’ (better readable) QR.
