if we switch form on relay to an other is this change suppose to sync across all devises linked to a profile?
this already works, but there are bugs and missing stuff since that feature is experimental, in the next version should sync reliably in all devices
There is an issue Setting new added relay as default fails to sync · Issue #7640 · chatmail/core · GitHub and the fix is not released yet. So if default relay fails to sync, it is a known bug that will be fixed in 2.38.0.
the migration form a profile with a regular email to and chat mail relay does also not work right now, right?
It works, you can add a chatmail relay to any existing profile.
Ok - i will test again… i had the feeling that i lost contact to few profiles… but i do my tests mostly on my own devises right now… i might have screwed up here things
