Link tab and file tab in gallery.
Explanation
I think these two tabs would complete the gallery.
a “Links” tab would be e great addition, indeed.
a “Files” tab is already existent on all systems, partly under the name “Documents”, but still.
Perhaps it would be useful to differentiate between documents (PDFs, etc.) and other file types.
+1 for the Links tab, and Files tab is the same as Documents tab, in any case maybe consider renaming “Documents” to “Files”
i created a pr for the latter: rename "Docs" tab to "Files" by r10s · Pull Request #2341 · deltachat/deltachat-android · GitHub
funnily, the code is also prepared for a “Links” tab, however, core lacks this feature.
Yes that is a good idea.
@r10s
Thanks.
In the desktop version the file tab is also called “Documents”.
Could you please create another pull request for it?
i created an issue: rename "Documents" tab to "Files" · Issue #2829 · deltachat/deltachat-desktop · GitHub
