The ability to remove media compression
Would it perhaps also make sense to have a compression setting on the receiving end? I do sometimes suffer from inbox bloat, but it feels like that’s an issue I should address on my end rather than somehow convincing others to send using worse quality.
We are still hoping and waiting…
It would be very helpful if you could consider adding an option to select multiple files when sending.
Currently on Android, when attaching something as a “file”, it’s only possible to select one at a time.
This means that, for example, a photographer who wants to send 10 high-quality images needs to repeat the “send as file” process 10 times, selecting each file separately.
It can be quite inconvenient.
ftr, you can now send media without compression on all platforms, including iOS: use “Attach / File”.
that way, you can send selected files and media “as is”.
some answers to follow-up questions in this thread:
we do not want to have a “global, always” options for that, as this easily goes wrong. one does not always know or care about receiver capabilities. it is also not the default user expectation that sending a few images end up in 100+ mb of data, let alone some minutes of video eating several 100 mb uncompressed. most user do not even know or think about that :slight_smile: but we are considering from time to time if the current default compression is fine.
for multiple selection, and sending of compressed images: this is also available on all platforms.
for multiple selection and sending of files and uncompressed images: this is available on desktop, on mobile this is still missing, indeed
the latter is tracked at Ability to send multiple files and Feature Proposal: Multiple Attachments in one message - it is just not done yet. while we are obviously able to do things, we are short in resources and money. we have to weighten a lot. any donation will help :slight_smile: https://delta.chat/donate
We should think of something. Or we will add another compression option “without compression”, but initially users will still have a balanced mode.
That’s a great idea!
Please add
Outgoing Media Quality - without compression (Original)
This idea has already been implemented in a mini-app. The limit is 500 MB. Third-party resources are also included.
