WebXDC insert menu suggestion
Right now we have to download WebXDC apps from a web page and then attach them to chats using the attachment > file menu. I’m thinking about a more user-friendly and discoverable method.
Perhaps in the Delta Chat settings there could be a field for “WebXDC app repository” where users could enter something like: webxdc apps
Maybe that’s the one that’s there by default or is suggested just like the video call server setting has a suggestion.
The repository URL could have some text file like JSON or XML or whatever that the Delta Chat client downloads and formats into a list of the WebXDC apps with thumbnails and descriptions or whatnot. The Delta Chat client can use that to create an app selection screen that users can scroll through, choose an app, and insert into the chat.
By having a WebXDC repository URL field in the settings, anyone can make a repository server that any user could add to that field to create an apps menu.
The json already exists and is used by the website you linked to https://apps.testrun.org/xdcget-lock.json
Currently there is also a webxdc store bot at xstore@testrun.org that gives you a list you can use right inside of deltachat.
Might make sense to integrate a webxdc app selection into the app, the web request is not that evil after all, if you can define the repo urls yourself.
Yay! I see the new menu on the Android app! Nicely done!
Good spot for adding/changing the repo URL in the settings too!
THANKS! Much easier for people to find and launch apps & games now!
for the record, the app-picker is rolling out on iOS just now as well …
… and soon on Desktop …
