What are these blank emails with an .asc attachment?
In some instances, I use Delta Chat for a preexisting email account that was in use before adopting Delta Chat. Some correspondence must be shared between two or more email clients, and it’s necessary sometimes to reply via a non-Delta Chat email client to a thread started on Delta Chat, or vice-versa.
When checking the correspondence from Delta Chat in another client, I discover dozens of blank emails holding a .asc attachment. I haven’t tried decrypting these yet with available keys, I figure it’s probably a shorter route to inquire here first.
My concern is that these emails are somehow necessary for communications and that if I delete them or relocate them, it will break threads or otherwise somehow prevent communication with a user.
This didn’t happen in the past. Admittedly, I haven’t been staying as up to date with development of Delta Chat as I’d like to.
I’ve read a little here in preparation for this post, and it seems that these emails may be some kind of contacts sync feature, and that using Delta Chat with other different clients isn’t recommended now.
It would be very bad to trend in a direction where Delta Chat can’t be used in conjunction with other email clients without complication, awkwardness, or danger. Part of the significant value of using SMTP for a messenger protocol is its portability across different environments.
Also, it would have been wise to notify users as to why these messages were going to start appearing before, or as, they rolled out, rather than saying “you weren’t meant to look in those folders anyway” or “you should only be using Delta Chat with a dedicated email account” after the fact. If at all possible, these emails should be explained carefully somewhere.
not getting spammed by unexplained, mysterious emails
dozens of emails with no content and unreadable encrypted files suggesting that messages are somehow being missed by way of some incompatibility
  1. send an email from Delta Chat on mobile
  2. check email folders for the account in question on any other email client
  3. discover dozens of unexplainable emails
Screenshot_2024-06-27_15-31-46
Speaking as someone who’s not very familiar with Delta Chat’s inner workings, I suspect those are E2E-encrypted messages.
https://delta.chat/en/2023-11-23-jumbo-42
FAQ also has this entry “How can i get an end-to-end encrypted chat with a Delta Chat contact who sometimes uses webmail or another non-Autocrypt e-mail app?”, which might be relevant:
You said you are already using Delta Chat together with another client, and the issue is just that there are some extra emails that you don’t know the purpose of?
But again, maybe it’s best to just wait for a response from someone more knowledgeable than me.
I possibly posted this in the wrong category, maybe I should have put this in User Testing.
I very much doubt these are actual messages, if for no other reason than I’d most likely have heard in-person by now some complaints about missed replies.
Here, this may help:
@hpk
@r10s
@link2xt
@ghostlands I suspect these may be sync messages though given your “steps to reproduce the problem” i can’t be sure. Please check Encrypted attachments in regular email - #19 by iequidoo also, maybe it will be helpful.
EDIT: Now Delta Chat syncs many things, not only contacts. E.g. some settings, chats archived/muted states etc.
EDIT:
No, there are no plans to complicate using Delta Chat in conjunction with other MUAs. All such problems should be fixed.
