1:1 & group chats should be shown in separate lists ideally or at least marked distinctively
Hello,
just like in my Android XMPP client the list of 1:1-chats and group chats becomes confusing quickly once populated. Having a lot of 1:1-chats alone can make it so. So my feature request is that groups and 1:1-chats get separated in the Delta Chat clients. UX wise their should be two tabs in the title bar on which the user can click on to switch between the two lists. Additionally the user could be enabled to switch between the two lists by swiping left/right, which is a gesture that’s so far unused in Delta Chat clients AFAIK.
If the two list proposal is either deemed to be bad or will take long to implement I would suggest to at least or for a temporary solution mark the two types of chats clearly. I tested it in the current state by having a contact called “Werner” and a group called “Werner” and there was no indication in the list about which of the two was the 1:1 chat and which was the group.
Thanks for reading! Greets!
See also
