Hi everyone, I’m just dealing with delta chat due to increasing censorship in my country. I have posts on Hestia and delta chat functions perfectly on my mailbox, except for calls. I know that you can configure chatmail using Postfix SMTP and Dovecot IMAP, and Hestia uses Exim. So I just wonder if it’s possible to set up Hestia so that calls appear? Thanks
Delta Chat gets the TURN server string from the mail server’s IMAP metadata:
If you’re running a custom non-Chatmail server, I think you can add this field manually, I think it can still be a static string. Just make the username a timestamp that is super far in the future.
Thank you, it’s still a bit difficult to figure out how to apply this to the HestiaCP installation, but I’ll think about it. In general, it would be good to use, as I already said, your turn, such as in matrix synapse or ejabberd. Just as I understand the file transfer is limited to 20-30 MB, which also offers to install GitHub - chatmail/relay: chatmail service deployment scripts and docs which doesn’t make sense to me, since I have both ejabberd, synapse, and hestiacp). But still, in my opinion, as a backup messenger delta chat is very good, thank you for doing it!
