Chatmail certificates under a reverse proxy
Hi.
I would like to install a Chatmail server under a reverse proxy, but I am having problems with the certificate.
My reverse proxy is already forwading traffic to my other backend servers, so I cannot directly stream port 80 and 443 towards the chatmail server in order to let Chatmail handle its own certificates.
I guess one solution would be to make the reverse proxy manage Chatmail’s certificates.
Would that be a problem?
Is there anything at cmdeploy I could easily modify -without breaking anything- so that Chatmail forgets about certificates and everything works ok?
If so, please let me know.
Thank you!
I guess another solution to my problem would be to make Chatmail negotiate its own certificates through DNS challenge.
Is that possible?
How should I proceed?
I solved it.
I am using Nginx Proxy Manager. I created a Proxy Host (http/80) with the three hostnames mychatmail.mydomain.tld, mta-sts.mychatmail.mydomain.tld and www.mychatmail.mydomain.tld and then, on the advanced tab I added:
location / {
  return 404;
location ^~ /.well-known/acme-challenge/ {
  proxy_set_header Host $host;
  proxy_pass http://<my_chatmail_local_IP>:80;
My previous post only solved passing the scripts/cmdeploy run but when I ran scripts/cmdeploy test I got errors.
So, the final solution was a proxy host https/443 for domain names mychatmail.mydomain.tld, mta-sts.mychatmail.mydomain.tld and www.mychatmail.mydomain.tld, letting NPM request letsencrypt certificate and adding the following custom configuration on the Advanced tab:
proxy_ssl_server_name on;
proxy_ssl_name mychatmail.mydomain.tld;
I enabled the options:
  • Block Common Exploits
  • Websocket Support
And on the SSL tab:
  • Force SSL
  • HTTP/2 Support
  • HSTS Enabled
Hello! I have the similar issue. However, my reverse proxy is Apache Web server. Could anyone help me with a site configuration to pass web traffic to a chatmail server?
Moreover, I’m also interested in how to move acme and nginx from 80 and 443 ports and run reverse proxy on the same machine.
