Improvement for using voice messages
Continuing the discussion from Confirmation of Receipt not reliable:
The option to
  1. stop and
  2. continue voice recording and
  3. submission, in a separate step would be nice.
The microphone button has to be
  1. hold pressed during voice recording and the
  2. voice message is sent instantly and automaticely at releasing the microphone button.
  3. No chance to stand back from sending after the microphone button has been pressed once, no chance to stop and rethink about, no chance to add something, no chance to generate a voice mail in multiple sequences.
NOTE: now you don’t have to keep pressed the record button, you can lock recording
Now = in nightly Android builds only?
This is not possible in common VMB’s (voicemail boxes) either. Not sure how we could integrate such a feature in the UX. I would say, if voice recording must be “produced” (stopped/cut), this should be done with another app. The result (sound file) could be shared with the Delta Chat app afterwards.
I know the feature to start, stop and continue voice recording from multiple other apps and messengers.
I guess, I wasn’t clear enough, what I meant with “multiple sessions”.
Maybe, additionally to the proposed feature, an optional “walkie-talkie-mode” (i.e. push-to-talk) could remain in DC?
(Says me who has never sent a voice message at all).
PS. BTW, yet another option. :wink:
@CrazyM You can already invite chat members to video chats by sending the appropriate links to them:
If you do not want to use video, just disable your webcam before or after joining the conference.
Fully support the first message in this thread :+1:
Especially the point “submission in a separate step” would be very welcome.
(pushing send button for sending would be great)
Muchas gracias por el trabajo que hacen los desarrolladores, en especial a la comunidad de Cuba de Deltachat. Una sugerencia en la que se puede trabajar es que el audio corra continuo cuando están uno a continuación de otro en un mismo chat. Ya que se torna un poco molesto darle Play por cada audio, y lo otro muy importante es que en sistemas Android al apagar la pantalla no se detenga el audio que está reproduciendo en el chat.
Thank you very much for the work that the developers do, especially to the Cuban community of Deltachat. A suggestion that can be worked on is that the audio runs continuously when they are one after another in the same chat. Since it becomes a bit annoying to give Play for each audio, and the other very important thing is that on Android systems, when the screen is turned off, the audio that is playing in the chat does not stop.
