Make connection status more visible
Another one for my “make X more visible” series :wink: :
Some users complain that it isn’t obvious if Delta Chat is connected or not, Delta Chat shows toasts with some errors or “network unavailable” but it isn’t obvious for the users if after that they are connected.
In the case of Cuban network, disconnections happens a lot, since the network is slow and unstable.
So I suggest a more attractive and visual way for the user to know in any time if they are connected or not. I would like a bit of brain storming here, one basic idea could be to use the Delta Chat top bar colour to indicate the connection state, for example some red for disconnected and the default colour if everything is fine. If you come with a better way please share!
example of a basic solution(just to trigger your imagination):
It’s always good to only have a single place to look for a status.
When there is no connection to the email server, there could be a zigzag or lightning across the INBOX counter icon:
downside is that in-chat you will not know
I agree with this but that “single place” should be visible everywhere in the app…
another idea:
maybe not the whole bar but some kind of thin undefined progressbar close to the top bar, something like the thin progress bar of github pages(when loading), as example, but undefined(no progress)
Hm, right.
Or, what about maybe graying out the screen or background.
Maybe easiest, and just fine, simply let the current “network unavailable” overlay notification stay (not fading away again) until the connection is reestablished.
This also have inconveniences, graying out the whole screen may be unwanted as people may want to read offline the messages, and the background is not visible everywhere and both have issues with the dark mode or with custom backgrounds, that would be much more complex than using the top bar.
There could be another errors, people will find Delta Chat buggy if Delta Chat says “Network unavailable” and they can check that others apps have connection and the network isn’t unavailable at all. And also the notification if will be a toast, as it currently is, will be a bit obtrusive.
Maybe It’s that I don’t care at all, but, why don’t you just put something like “(offline)” next to Delta Chat in the title bar? I mean, it’s the simplest way.
the title “Delta Chat(offline)” is only visible in the main screen, not in chats, groups, etc. where there are no space to put that word
ok, but then you could use an emoji or something like that. I mean, in the future we should be able to play with the colors of DC, so it’s safer to make this kind of notification with a picture/emoji/whatever
This is used in Wire.
Yess!!! something like that is what I was talking about when I said:
that will be visible everywhere and compact and much better than my initial basic idea of changing the bar colour.
I think the color bar is a good idea.
A simple and easy to see solution. But they must choose a very remarkable color …
To this end please also visually indicate imap/smtp authentication errors. Bad password, sure, but timeout errors, and throttling errors also.
