Reduce space on internal storage, disk full
And fill all device’s space at some point, right?
I still can’t get it, why not to use K9 model of keeping messages that proved by time.
It really simple, - keep on device the only number of last messages user wants, for example 100/250/500/all and keep rest of messages on the IMAP server that can be pulled on demand if needed.
Messages that deleted on device should be deleted also from a server. Simple.
This way, those who has limited space on IMAP server can manage what to keep and what can be deleted. In the same time those who has “normal” or huge amount of space on the IMAP server, they can keep messages without killing mobile device by filling all its space (which is very easy to achieve with attachments) and be able in the same time get old messages if needed.
DC isn’t snapchat to exchange with kitten once and forget about it, but a communication program that utilized email protocol that assumed to keep message forever if it needed.
I already has two correspondents(a lawyers who exchanged a lot with attached documents) who stopped using DC because of this issue and early or later every1 will step on that if it wouldn’t be resolved.
AlexJ I was talking about to keep them forever in the server by default, but let people with small server storage opt-out, maybe you have almost infinite storage, but some people have only 100MB :stuck_out_tongue:
actually I think that would be a nice (optional) feature for Delta Chat
According to the title of this topic, - the issue is that DC keeps locally, on the phone ALL messages including blobs and fill out device’s space.
I’m talking about majority of users who has more than 100Mb on IMAP server and proposed solution how it can be resolved, - the same way as it done in K9.
All phones I know allows for example to set preference - how many text messages to keep, the same option need to be implemented in DC to avoid putting smartphone to the knee.
Actually it should be more flexible to satisfy people like you who has limited space on the server and those who can at least use gmail or their “friends”.
I see it as an options:
  1. Keep locally on device only last: 100/250/500/All cached messages and allow to pull older messages from IMAP server on demand
  2. Automatically delete messages that older than: month/year/none(keep all)
  3. If option #1 is set to “all”, then unhide option: Delete old messages if space occupied by DC exceed 0.1/1/2/5/10/9000Gb
I think it will satisfy all DC users, those who has plenty of space on IMAP server and those who has limited amount of space and what is most important phones won’t be overfilled by DC in all cases.
Properly solving the message history and storage usage (devices/server of any sizes) for all use-cases, while keeping it to a minimal set of user-visible options, isn’t trivial, but shouldn’t be too hard either.
IIRC the required user-facing items for the full solution are only three:
    1. Additional message states: starred (never deleted, manual selection) and archived (usually remain only on device, automatic expiration). (The other (recent) messages get synced with the server and across devices. NOTE: The “archived messages” are different from the old “archived chats” which are only hidden/suspended from the chat list. The “archived messages” stay visible in the chat histories, are not synced with the server (and thus other clients) anymore, and default to remain only on the device.)
    1. Max. number of messages kept on server, and thus synced accross devices (per chat), default value 250? (The client with the smallest setting usually determines the amount of messages kept on the server.)
      • Default true: delete exceeding messages from server
        Disabling this suboption
        i) in conjuction with reducing max. messages kept on server/synced to 0, configures a device (with enough storage) to keep all incoming messages , while other devices may still sync more and even delete a part of them before they expire on the server.
        ii) in conjunction with a smaller number kept on server and synced, and possibly a small archive limit, configures a device to sync less messages than kept on server, i.e. for low-storage devices or huge-storage servers.
    1. Local (archiving of) messages. Keep messages that expired on server on local device? Default enabled/disabled? (enabled is safe if auto-delete-device is implemented)
      Suboptions:
      • Default disabled: Limit number of (synced + archived) messages (per chat), to limit the number of messages kept on the device after they expire from the synced messages.
      • Alternative option that will also remove low-traffic chats: Default disabled: Limit age of (synced + archived) messages (per chat)
Required background mechanisms:
  • auto-delete-server
    • always guaranteeing enough free (quota) space on the server for continuous operation (and only deleting the last (synced-new) messages of every chat if no other option remains.)
    • limits the max. number of messages kept on the server
  • auto-delete-device
    • guarantees free space on the device (maybe auto-deleting from the synced rather than archived? (and first reducing the the local email inbox list?), or offering to delete/backup archived chats if necessary)
    • optionally limits the local history if configured
A full current design:
(It has some more details like considering the latest messages of each chat (state synced-new) more important, to prevent the auto-archive and -delete from completely deleting low-traffic chats etc.)
I optimized the config options above.
In current 0.200.0 there is the housekeeping function at backup export which deletes unused files.
this works well (imho)
beside of that there should be an automatic or manual function to do this job separately from backup.
Would it make more sense not to use a per chat value here, but the total messages on the server?
One detail of the above background mechanisms would actually make deltachat work without requiring manual adaption of the default number of max. messages kept on the server/device (out of the box) also with small mailboxes/storage:
when the free space falls below say 6% or 110MB, notify the user that DC will soon (below 5% or 100MB) have to start automatically deleting the oldest chat messages on the server/device
Can we use SD Card for messages and Media and whatever doesnt need to be in internal memory please?
this is already answered some posts above, Reduce space on internal storage, disk full - #7 by r10s , i think the arguments are still valid - plus, average memory has grown since the 5 years old post
for sure, there are usecases for external memory, but it seems still be a comparable low impact for lots of work and maintainance, so resources are spent better elsewhere. esp. as one can increase the memory on system-level with SD cards on many OS (probably on more OS than 5 years ago): Get started with an SD card - Android Help (see “internal storage”)
i have redmi 9 nad tried the workaround to enable sd card as internal but after a week i guess there is no garbage collector and even when i deleted all apps tht where only internal i couldnt install any app and i got constantly a warning that my internal space is always full, had to reset to factory and just accept that i have only 32gb internal…
my current phone doesn’t even have SD slot, I guess SDs are too unreliable (they break eventually!?) and you would lose all the data including all your Delta Chat messages and chats that would be awful
funnily, sd-card-slots are more common in budget phones
i do not think, this is true in general. sd-cards are used in various professional settings.
what’s true is that you can easily buy “bad” sd-cards, slow ones or fake ones that claim to have 1tb for 20€
physically, the sd-card-slot is often placed nearby sim-card, sometimes you even have to remove battery - so it is more a insert once and done. so, the risk of physical damage is also low
for sure, it also depends on android version and manufactor, how well “internal” storage work, but it may be a nice solution. alternatives are more onboard storage or “delete old messages”.
that said, using sd-card as “external” storage will have similar issues as “internal” storage - plus the ones mentioned above
In my experience (like 8 years ago) there sometimes were issues with the sd-card like android thinking it needs to reformat it to detect it, errors when you try to remove and read it without shutting down the phone and sometimes the sd card was not immediately detected, sometimes moving apps to the scared did not work. Still whatapp used it happily to store its data in a whatsapp folder - mostly the blobs (images and videos) though, not sure if they also stored the messages, I can not remember.
So at least for blobs sth we could consider, though maybe needs encrytption, because I don’t know if android offers isolated folders/containers on sd-card (to say that DC should be the only app accessing it’s folder)
I think this is a similar topic to mine from a few days ago (year 2025), so is it possible that this storage issue is lingering for 6+ years already without a solution? I sadly had to uninstall Delta Chat from my favorite phone which only had 32 GB internal space, because Delta Chat no longer could operate on it. I could not make it smaller, uninstalling-reinstalling did not help either, I just could not configure Delta Chat to either store everything on the SD card (the SD card storage is “unlimited”), or if it insists on the Internal Drive, then keep a max 500 MB storage and never extend beyond that. In its current form, as it is infinitely growing and only allows Internal Drive as storage, on that phone it is a useless app, alas. I keep using it on my bigger phones (which are newer, but inferior in many aspects to older phones), but not happy, because this “continuously growing size” is like a tumor, only a question of time before the new phones will be full, too. :frowning: Any solution? If not, why not?
I boot from my SD card, and Deltachat runs fine on it. But this requires a phone that can boot from the SD card. And there is a limit to the size of SD card my phone will take. Continually-bloating proprietary software that forces you to upgrade hardware is common, but not worthy of emulation.
Would it be possible to export your passwords, keys, and contacts, then import them into a fresh DC install, thus shedding the history and storage demands? If so, would it be possible to automate that as a minimal version of the add-second-device process?
Being able to export chats would be a useful adjunct functionality:
Related:
