Running bots inside deltachat
Many features require bots, but they don’t require “complicated” bots. I think it would be very useful to be able to run bots, aka automatic treatment of messages, directly inside deltachat:
  • Telegram-like channels (Can we have channels feature like telegram?) can be done with a bot that sends messages to everyone but discards all incoming messages
  • Individual bots, like downloader, AI, text to image, voice to image, Mastodon bridge… will only take instructions from me and talk to me, they will handle potentially private data so I’d rather use something I trust than something public
For many if not all of these usecases there’s no need for an always-on computer running somewhere, I can do it from my own device. But if I really want to I can install DeltaChat anywhere and run the bot there.
There’s a huge security window to look at here because the bot should be able to basically do anything
The ability to host client-side bots (bots running in a Deltachat client) would have advantages.
  1. easier to host and test bots
  2. harder to block bots (especially if they offered their own source code)
  3. harder to do traffic analysis (is the target talking to a human or a bot? is the target a bot?)
  4. easier to add experimental functionality to the client
The main disadvantage, bot downtime, could be mitigated where necessary by hash-based indexes of identical sibling bots, and people sending bot contacts to one another. At least one of the identical bots should be up almost all the time.
Security
Bots could be public, private (ignoring messages not from whitelisted contacts), or internal (interacting only with the accounts of their host client). Internal bots could implement functions (like link preview, backup, reading aloud, transcribing, etc.) if added to a chat.
Bots could be given permissions (access the internet through this proxy, write to this local directory, access microphone or speaker).
Examples
  • A mailman bot could run a public mailing list.
  • A vacation-response bot
  • A screening bot could transfer a new contact made via a posted QR code to a new account with an unpublished key
I have experimented with this in the past, I created channels and also anonymous super-groups via bot in the middle, and it was extremely slow, because the bot has to forward (and encrypt) the message to every member, having one bot per group/channel it could kinda work but still worse than the actual channels that are going to be added
Speed does sound like a showstopper for some types of bot, then. I’ll look forward to the new channels (which I’m guessing will be P2P, not like mesh-networked bots, where each bot sends a message to two or more other bots via mail servers).
I assume channels will not have the functionality proposed for individual, internal bots.
Many existing bots and proposals could be ported that are delay-tolerant and need neither Internet access nor relaying everything between a large number of subscribers, such as:
  • moderated forums (PixelSocial, DC-Confluence, DC-Community)
  • multi-player games (Deltaland, others where a game master is needed such as Werewolf, Mafia, Amongus and Among-sus)
  • webxdc gallery (xstore): share apps (and client side bots) with each other
  • Public Bots index: send the contacts and description of all known bots, being able to update via gossip
  • Group Editor Bot: shared notepad with resending
  • FAQ Bot: pin posts and save a tag for each
  • stalebot: invites users to a group and removes members whose last seen date is greater than 30 days
  • Yozuk: programmer’s utilities
  • mutual credit system
  • database: store, index and keep updated a relatively large database to allow others to execute full text search on and browse from with less traffic, such as documentation, mirror of DC source code, animated stickers
  • synchronize achievements across groups such as game high scores or certain calendar events
  • karma & praise: maintain a per user counter that can be incremented by others
  • moderation bot to kick based on bad words or big attachments
  • scheduled delivery of messages: send later, remind later, reminders for recurrent events in calendar
Many IRC and XMPP clients had hundreds of such client-side addon “scripts” in the 90s and these could also be ported.
Yes, it would be great to have an Android app like in the good old days with IRC: you install it on an old Android phone, set it up, and that’s it — the bot works. That’s cool. I tried to run the bot on Android via Termux, but unfortunately, no matter what I tried, the Delta Chat core does not deploy. Maybe I was doing something wrong.
But I implemented another approach: I installed the Macrodroid and Delta Chat apps on Android. In Macrodroid, I set up a trigger for new notifications from Delta Chat, and Macrodroid sends a direct reply via the notification. All that remains is to process the incoming command and generate a response to it.
(Copied from other topic)
The more powerful feature hinted at here is not necessarily about running daemons 24/7 on your SBC or inside Termux. It is about allowing extensions which run inside DC itself. Depending on configuration, such an extension will either serve only the local DC user in front of the device, or other contacts as well. This could enable running such bots anywhere, including on the client or on your own server, only if they were implemented in JavaScript or WebAssembly.
If said extension (or the extension library or framework) is implemented with decentralization in mind, it would be feasible to add the same bot code to the same group on multiple accounts.
Imagine you wanted a bot in your group that replied with the result of a dice throw when one sends the message “/dice”. Whoever happens to have said extension running within their client could respond to this request given no other member had responded already (with agreed-upon priority and delays between members of the same group to cope with up to a minute of latency). Such decentralized bots could also deal with the common use case of what happens when the bot server is temporarily down (for a few days) and could fill in the role of the bot by taking turns. If a sufficient number of members are running the given extension in various time zones, the availability of such bot service could be nearly 24/7.
That seems a very clever solution!
There is also this framework for webassembly plugin: GitHub - extism/extism: The framework for building with WebAssembly (wasm). Easily & securely load wasm modules, move data, call functions, and build extensible apps.
