Every time I click “link” to share my invite link, the link is different - it’s reset automatically.
I do not reset the link manually.
Besides that the old links allow to add me.
Is it a bug or is it a feature? ![]()
Android, 2.35.0
I think it always worked this way - producing a separate link for each person whom you invite upon each click. And this had never invalidated past links when producing a new one.
If you wish to refer to invite links you have given out in the past for some reason, you may want to list each of them in your chat titled “saved messages”, also noting for each the person you intended it for to possibly invalidate it after they join.
To invalidate an invite link you have generated earlier (so called “reset” in DC), you need to click the invite link yourself and then select the option to reset the given link.
If you found this answer helpful, feel free to mark it as a solution to the topic.
This answer in not helpful at all.
Even after “Reset QR Code” the old links allow to add the contact and see profile picture.
“If you wish to refer to invite links you have given out in the past for some reason, you may want to list each of them in your chat titled “saved messages”, also noting for each the person you intended it for to possibly invalidate it after they join.”![]()
See also
Can’t find the forum post, but many people also publish a QR code for one profile and then transfer contacts to a new profile.
I asked @adbenitez about it on his DC group. He wrote back that for him there was no benefit of automatic resetting invite links.
Can the Delta Chat developers explain what the benefit of sharing different invite links every time is?
you may want to consider opening an issue on the client repo you’re experiencing this with to describe the behavior and the expectation. having it formally documented would be helpful.
i’ve not had invite links invalidated (yet). to be sure you can replicate it, please ensure you’re on the latest client which as of this writing is 2.49.1 of core, but 2.50 is rolling out. there’s been some changes, likely unrelated to the issue you’re experiencing, but it’s helpful to debug with the latest client
