Overview of who read/saw last entry in a group chat
It would interesting to have an easy way to see if members of a group read/saw the last entry of a group chat.
What does actually indicate if we see a double check symbol on a post we posted into a group chat ?
just realized that if we view the list of the members of a group - the order is sorted by the date of the last visit - so this is already a good indication
If you enable read receipts in your settings, then you can find who viewed your last message (if they have the same setting enabled) if you click on … → Info.
Feel free to use the solution button if this matches your request exactly.
Thanks if you click on … → Info did the trick
Glad to hear that it worked for you.
Just for the sake of completeness, an hourglass after the message means it is queued for sending, a single checkmark means it was accepted by your server, an exclamation mark means any of the recipients had produced an error and a double checkmark means no error was received and at least one of the clients got the message.
It would be great if avatars could be listed instead of a double checkmark similarly to how other messaging apps work.
The following issues are also loose related (for indexing purposes):
true
I also dealt with some user puzzlement about what thhe checkmark meansr in a group, especially when some members turn off read reciepts. Thanks for the info.
now we have a “views count” for channels probably it would be much more useful to have the same for groups instead of double checkmark, that way you can know quickly how many people saw the message in the group,
but sadly most other apps don’t do this in groups, so I suspect it would be a bit different, but much more useful imho than the double ticks in a group, maybe I go for it in ArcaneChat
in any case the message info dialog needs to be improved, it is much better in desktop already
