Subject of emails
Not only @Oreyoter @hpk
What do you think of the “bridge” idea to only implicitly visualize the resulting subject in the text editor (for sending, similar as in received messages) with a hyphen - like in below examples?
Do you still see any intricates?
The subject may look (be marked) the same way as in received messages, i.e. ending with a - but additionally with a grey background.
For regular chat messages, the written text in the editor could be prepended with a lock that indicates that the message is going to get encrypted.
  • 🔒- Written text…
(Here the background and - hints to the canonical subject being used in the resulting autocrypted email.)
But in cases that an unencrypted email is going to be sent, the entered text would first be part of the subject and thus written with the grey background.
  • 🔓 Written text... up to max subject length - further written text.
Entering a new line within in the “subject length” could manually end the subject, at any time, allowing to thoughtfully choose and write a subject (if desired).
The marking in the editor might even be with only the - at the end (without a gray background), to be less noticeable, but still visible. However, I think writting the text starting with a grey background would also provide more attention to when the message is going to be sent as plain-text, which is a nice effect.
My only concern is the subject changing at every new message. A fixed subject or a subject that lasted, let’s saysay 24h, would be good enough to keep the destination box organized.
Yes, “subject keeping” is a good point. And it would also be a requirement for Reply to Message and mailing list support.
So how could the classic subject handling be integrated nicely in the UI?
Idea:
  • Non-chat, classic email messages could be displayed with some sort of reply button ↺ .
  • Pressing the reply button, could open the text editor box then prefilled with 🔓 Re: The current subject-, and the cursor already positioned behind it.
And concerning your aspect of message threading errors at some contacts’ clients (email client that only sorts by subject text but not based on headers):
As it can not be expected that contacts switch to another email client very quickly: Either a per chat or per contact setting, or even better shipping with a list of affected email clients and automatically using the “subject keeping” if a recipient uses such an email client.
I like current logic. Chat prefix gives new people the idea that you are in chat-mode with them and you expect a quick answer right now, not a lengthy tomorrow.
And beginning of the message in subj let people reply via ordinary clients faster (espesially using mobile apps): they starting to read you starting from notification.
When the message is encrypted it doesn’t leak to subj.
Everything is perfect! )
Why not to archive DeltaChat folder once in a while?? Sounds pretty simple.
Then your other MUA users have to use the same software to be able to call it the “Chat”
Then you simply use normal MUA to communicate with other MUA.
Chat isn’t normal full blown email.
Why are you using the chat application, if you’d like functionality of email client?
If you are saying “my email”, it means you have to use email, not a chat. Just forget that DeltaChat is using email transport under the hood.
What do you want to do with DeltaChat with such proposals - it won’t be neither Chat, nor normal eMail client.
Chat messages are generally short and don’t have “subject” properties. It abnormal for chat message to have “subject” for such type of applications. Chat applications don’t exhibit email properties such as threaded conversation. Mixing features you want, simply making DeltaChat to became DeltaEmail.
I really can’t get it, why not already use bunch of existing tools that behave as you liked (email clients aka MUA) instead of attempting to convert chat app to some kinda of hybrid monster.
Could you please explain, why ???
Personally, it is because I like the chat-like interface a lot more:
  • I can find a specific email in seconds, even if I received it months ago (because emails are sorted by sender)
  • I can also see what emails I sent along with the ones I received
  • I do not have to click on an email to read it
  • Replying is a lot faster
  • it just looks better IMHO :upside_down_face:
…and I am not using a chat client because I want to make use of Delta Chat’s most important feature: Compability to emails.
add to that that it is easier to share pictures and other media, and to record audio and now video, also the media compression stuff is important to me.
But just to be fair, some aspects you mention are possible in a classic email app like k9 mail, for example, I am testing the UX of an user using k9 to chat with delta chat users, and after some tweaks it is not that bad, for example you can enable the thread view which will group messages by dc chats, you can disable the option to save the messages you sent in the Sent folder and use the option to set a bcc address to send a copy of your messages to yourself that is what Delta Chat does, and your own messages will be shown in the threads, you can customize the number of lines of email preview in the email list to 6, so for short chat messages you don’t have to open the email,
this is the closest to a Delta Chat app I could get with k9, and it is not that bad, honestly I was expecting to be a hassle to chat with a Delta Chat user using a classic email app but it was not the case :slight_smile:
I think there is about no point in trying to convince “to subject or not”. The case has quite clear conditions.
Re: ... messages are required for mailing lists. But once implemented, the same visualization can also be very useful for direct in-reply-to answers in group chats: Referencing the original message even if just by showing a clickable default link “Re: First few words…”.
Otherwise, for chats, the subject is only relevant when sending non-encrypted messages, but this can still be integrated seamlessly and nicely.
The subject can be visualized and written in the editor completely unobtrusively for unencrypted messages, for example, with a slightly darker background. Together with visualizing the encryption state it may go like this:
🔓 When writing an unencrypted message, the text written until the max. subject length is then shown with a darker background while the typing can just go on normally beyond that. The resulting subject of the unencrypted message is then easily visible, and understood without requiring reading of documentation. And after seeing it in action when communicating with plain-email contacts, it will also become useful (for those who care) that the subject is easy to control:
🔓 A shorter subject
is very easy to “define” with this visualization scheme, if wanted, just by starting a new line before reaching the max. length of the subject.
Actually, I do not think that I would understand this :frowning_face:. Also, it would annoy me.
Well, don’t you think you already understood it? And think it would annoy you?
OK, but why is that so?
Please remember that you would only see the slightly darker background, when writing to a classic email contact, where the handling of the subject really makes a difference.
Consider how annoying it can be to classic-email contacts…
Consider how annoying it can be to classic-email contacts, to read always self-repeating messages from deltachat people, that don’t see the emails they send out.
I understood it because you explained, it, but I would not understand it without documentation.
By the way, would you idea mean that the chat: prefix is added?
When we first touched the Chat: prefix in this thread (proposing this for the mixed-environment:)
the thought was about making the default deltachat prefix short and to find a way to mention the group or topic for the email recipients. And -[] could be a short, language independent “chat prefix” ( possibly even seen as symbolizing a text bubble). It could hold the short group name for group messages, and a closing | could indicate to the recipients that there is no more text in the body to look for.
I think a short chat prefix is nice to indicate the “chat mode”, it would only have to be omitted for classic Re: replies to mailing list messages and maybe messages that clearly classify as emails.
Maybe we can still find a better idea to visualize, and to allow specifying the subject (for Re: replies and classic chat-thread starting messages) for good measure at classic email client contacts.
What do you think?:
One point I noticed now is that the visualization in the editor would only be necessary for non-chat messages after the text gets longer and does not fit entirely into the subject field anymore. Do you think only visualizing the subject part then could reduce the annoyance you see, and resemble more closely the “problem / issue” or the way that the recipient sees the message?
🔓 Using bold text to indicate the subject in longer messages
would also be possible and might come more naturally, since headings are frequently seen in bold letters.
When you’re viewing a chat, would it be possible to add a menu item, “Set Current Subject,” which causes every message you send to have a particular subject line? And then from now on in small text at the top of the screen, under the group name / recipient name, there would be a small bit of text saying, “Subject: [Whatever]”
That would make it so you can have a fully customizable subject, but still maintain an instant messenger-like feel.
I personally am not very interested in having a standard format that I can’t change. I would like fully customizable subject lines, if possible. This would allow me to be less self-conscious when sending quick messages to traditional email users.
Sounds good.
These “chat topics” might even provide a way to fully represent a translateable concept of email subjects into chat views, instead of only allowing for some visualizing and editing in individual messages. The topics could allow to break a long list of intermingled messages down to a subject’s sub-tree of interest.
The subject or “topic” line that is shown at the the top of the screen, could not only allow to change the subject of the resulting email, but also to show a selection of subjects in the chat, that allows to filter out corresponding messages and reduce the view to the selected subject and its follow-ups.
This could very much ease the navigation in larger amounts of messages like on mailing lists (https://github.com/deltachat/deltachat-core/issues/125).
I think this would be more complicated then the current messenger view.
A messenger should stay easy.
There is a logical grouped thread for every contact.
That’s the advantage of a messenger.
So I think it’s not a good idea to put things like this in the UI.
A messenger is a messenger and a Mail client is a Mail client.
This should not mixed to catch “non tech WhatsApp users”.
If you have developing skills you can fork DC an build a hybrid mail/chat client.
I think there are a few people who would like it.
But I’m sure more the 80% of the normal users want a simple to use (UI and UX) messenger.
Yes, and I think the idea of “chats” is very good. The default would not, nor should, have to change.
(The Email-chat spec simply allows to correspond with any email address, thus also those using classic email subjects.)
Deltachat for itself would not impose a requirement to use subjects in its messages. But if some contact starts writing with different subjects (to stay on top of a larger bulk of messages) deltachat could just show the subject at the top of the chat (idea from pcrockett), and provide a filtering possibility (a search box, with the list of subjects already used in the chat, similar to “suggested search terms”), that gets shown by tapping on the title, whicht could have some “drop down” or “expand” icon to indicate this feature.
Showing the subject in the title also reduces the redundancy that would result from displaying subjects within every message.
As long as no customized subjects are used in a chat, everything could stay the same as it currently is. (Except the small indicator?)
One remaining question might be how to best allow deltachat users themself to do a first custom subject change. A tap on the title currently opens tabs for the group settings, gallery and documents, maybe that could just as well open with a new (to be introduced) tab for “subjects” or chat “topics”, containing a “plus” button for adding a custom subject.
I am not particularly interested in the subject in DC, but such insistence should be heard.
:page_facing_up:In the picture I show you how the matter looks in a normal SMS messaging application. If SMS messaging applications with chat view, support subject and nobody has complained about it, they will tell me, in an email application, where by nature it takes.
I do not think that takes away presence in the chat view, also only those who are very interested would use it. For those who do not interest him, he would remain hidden.
The subject is only important in communicating with an MUA and only in this case should it be allowed.
:mag_right: In SMS messaging applications, there are two ways to add subject:
  • From the menu with an option “add subject”
  • Or with a long press on the send button
And for the visualization, it seems good to me as it is in the image.
Muchas Gracias, I didn’t know that SMS supports subjects.
So, there actually is prior art for traditional subject support in a chat app. :slight_smile: And there is the possibility to optimize it to support email lists by showing the current top-subject only in the header, and provide a top-subject message filter (as pcrockett imagined above).
Not sure if anyone already mentioned this here, but Spike has addressed a similar issue already. Every time a user tries to compose a message, a pop-up appears with the current Email Subject, and you can either delete it or change it. A similar thing could be done here. Screenshot below:
